waterballoon
- Apr 13, 2009
if you want ensure your Xiaomi phone is "local" - check for the EIN sticker on the box. EIN is the official distributor for XiaomiSG
Use 3rd party forwarder...I got one in Dong Guan quite Good...can pm if need it, will share her WeChat idTaobao they can't ship to singapore leh
13U 12/256GB at SGD1369?ezship can use wat
carousel, got PO liao. $1369 cheapest.
Bro pls pm me thx.Use 3rd party forwarder...I got one in Dong Guan quite Good...can pm if need it, will share her WeChat id
Please check pm!Bro pls pm me thx.
ezship can use wat
yap at 1369...13U 12/256GB at SGD1369?
but is it easy to flash to eu or global rom later when they become available?
seriously, if you are a new to flashing (and you are not willing to take time to research fully how to do it properly), i really would not recommend it. You can brick the phone at worst if you dont know what you are doing.13U 12/256GB at SGD1369?
at the cam part, is 15.4mm thick.
thats 1.54cm, before any phone case
jin thick!
