Xiaomi 13 series
Milo-Dino
Wonder how much singapore will sell international version if it arrives.. Maybe buy liao can consider get the camera kit from China when I go for business trip later in the year... (not keen on getting China rom phone so will not consider buying there)
vaxvms
This kind too extreme. Who in the right mind would keep shaking the phone? What I mean is daily use durability.
think variable aperture current best still huawei
xiaomi just wan market it as all in 11 combo of 3 brands HOV
vaxvms
saw malaysia seller 16/512 4588rm
if go KL can go see real phone in shop
rrr2015
variable between f/1.9~4? differences are insignificant. either want more bokeh or dof i think good enough for street photography.
also step mechanics simpler & probably more robust
rrr2015
already got user post the variable aperture is like very fragile
machiam if shake can turn F4 if shake phone again become F1.9
we don't even know if he's talking the truth. internet nowadays are full of people vying for attention
Milo-Dino
The f stops are good enough.. For portrait and for landscape.
Although in the past, I would also use f8 for my old full frame camera...
rrr2015
yeah i mean having variable between f/1.9 ~ f/4 is pointless. prefer f/8 for landscape but they already mentioned 13 ultra design for street. still wish they had brought over 75mm macro from 13 pro
andyhtc
Suspended
My 11u camera got problem due to cycling
I drop my phone quite frequently. Luckily my K50 Ultra with its tough casing is very robust. I doubt XM 13 Ultra's complicated camera system can survive my frequent drops.
andyhtc
Suspended
Xiaomi 13 Ultra: Tests show worse display efficiency than the Xiaomi 13 Pro​
In an efficiency test by Chinese outlet Xiaobai Evaluation, the Xiaomi 13 Ultra's Huaxing C7 display can be seen to be worse than the E6 display on the cheaper Xiaomi 13 Pro. While both are neck-in-neck at 100 nits, by 350 nits, the E6 on the 13 Pro shows an efficiency advantage, consuming just 0.933 W versus the Xiaomi 13 Ultra's 1.055 W. At the peak manual brightness of 510 nits, that gap widens further—the Xiaomi 13 Pro's display uses up 1.570 W while the Ultra's C7 panel guzzles 1.771 W of power.
https://www.notebookcheck.net/Xiaom...ficiency-than-the-Xiaomi-13-Pro.708582.0.html
ranmaru1987
sample image from normal xm13
