[SIC] Really good Ryzen mini PC
Op_Valkyrie
thanks bro. its under my radar. the models i have seen are intel. i prefer ryzen.
Look for minisforum - one of the best reputable mini pc in the market. Lots of different Ryzen build for you to choose from
Hafi
Beelink
Sometimes have promotion on amazon.sg
Can also compare pricing on Aliexpress, see which one cheaper
Note: no warranty
actually if you read some feedback on Amazon, Beelink will honor their "warranty" but make sure you buy from Beelink.sg and not other reseller.
networked
tbh, i miss the old chinese mini pc prices of less than $300-$400. anything else more its better to get a budget laptop.
Hafi
mini PC can replace tower desktop if you are not into high-end gaming cos using very little power and space.
vofzxy
Your link not working…. If you are referring to HX90G, that’s the older model from mine
hmmm, why not working leh?
https://store.minisforum.com/collections/amd-®-ryzen-®/products/elitemini-hx90g
i think HX77G is the latest release -- AMD Ryzen™ 7 7735HS & 6600M(HX77G) Minisforum
Minisforum HX77G
Processor
AMD Ryzen™ 7 7735HS , 8 Cores/16 Threads
(Total L2 Cache 4MB , Total L3 Cache 16MB , Base Clock 3.2 GHz , up to 4.75 GHz)
GPU - AMD Radeon™ RX 6600M(GDDR6 8GB)
Memory
DDR5 Dual channel (SODIMM Slots×2)
Supports a maximum of 64GB (32GB x 2) of DDR5
Storage - M.2 2280 PCIe4.0 SSD (up to 2TB)
Storage Expansion - M.2 2280 SSD Slot (Support NGFF SATA or NVMe PCIe4.0 SSD)
Wireless Connectivity - M.2 2230 WIFI Support (Wi-Fi 6,BlueTooth 5.2)
Video Output
① HDMI (4K@60Hz) ×2
② USB4 (8K@60Hz)×2
Audio Output - HDMI ×2, Headphone Jack ×1
Ports & Buttons
RJ45 2.5 Gigabit Ethernet Port ×1,
USB3.2 Gen1 Type-A Port ×1(In Front),
USB3.2 Gen2 Type-A Port ×1,
USB3.2 Gen1 Type-A Port ×2,
USB3.2 Gen1 Type-C Port ×1(In Front),
USB4 Port ×2(In Back),
HDMI2.1 ×2,
Clear CMOS ×1 ,
Microphone Jack ×1,
Headphone Jack ×1,
Power - DC 19V (Adapter Included)
System - Windows 11
Product Dimension- 205*203*69.3 (mm) / 8.07*7.99*2.73 (inch)
Package Dimension - 233*233*160 (mm) / 9.17*9.17*6.3 (inch)
Net Weight - 1.21 kg (2.67 lbs)
Package Weight - 2.72 kg (6 lbs)
Package Content
HX77G × 1
Power Adapter × 1
Power Cable × 1
HDMI Cable × 1
Base Support Frame × 1
Base Bottom Plate × 1
Technical Documents × 1
Mounting Screw Set × 1
Op_Valkyrie
Euqorab
I am trying to buy a Lenovo M75q Gen 5
https://www.lenovo.com/sg/en/p/desk...o-thinkcentre-m75q-gen-5-tiny-amd/len102c0051
But faced with so many build options
Which one should I take?
Processor
AMD Ryzen™ 5 8500GE Processor
(3.40 GHz up to 5.00 GHz)
Included
AMD Ryzen™ 5 PRO 8500GE Processor
+SG$20.00
AMD Ryzen™ 5 PRO 8600GE Processor
(3.90 GHz up to 5.00 GHz)
+SG$140.00
AMD Ryzen™ 7 PRO 8700GE Processor
(3.65 GHz up to 5.10 GHz)
+SG$240.00
Memory
8 GB DDR5-5200MHz (SODIMM)
Included
16 GB DDR5-5200MHz (SODIMM)
+SG$60.00
16 GB DDR5-5200MHz (SODIMM) - (2 x 8 GB)
+SG$70.00
32 GB DDR5-5200MHz (SODIMM) - (2 x 16 GB)
+SG$190.00
Processor and ram? Worth to go up to Ryzen 7? I intend to get 1x 16GB. Is there difference 2x 8GB?
