- Jul 5, 2001
Yes*Got the update
It fixes this?
https://9to5google.com/2023/03/16/google-exynos-modem-vulnerabilities/
Hi All,
I am a Pixel 6 user and I believe my questions are repeated but I will appreciate if you can point me to that resource. These problems seems to occur after I have updated Pixel to the latest version:
1. When I call someone or receive a call (via my cellular network), the call will suddenly drop and Pixel will prompt me if I want to enable Wi-Fi calling. This always occur within the fist 1 to 2 mins into the call and I have to call the person back again. However I would have no problems talking for 10 to 20 mins in the subsequent call. I am not sure if it is a SIM card problem or a bug. Try reset mobile/bt/wifi
2. Battery life shows 14+ hours when fully charged. I remember is shows 20+ hours before the update when fully charge. I read that a lot of people have this issue after the update and it is irreversible. Use the phone as normal for a week and things likely will be back to normal
3. I plan to sign up for a 5G SIM only plan likely with GOMO. However I am not sure if Pixel 6 supports 5G especially when there are true 5G an 'fake' 5G. https://pixel.withgoogle.com/5G/?country=SG
Any inputs are appreciated.
Thanks.
Hi all.. sorry to ask this but does Google cover US set here? I want to get a p6 here but it's not available at Google store anymore. Thinking to get US set from other sellers but wonder if cover warranty.
Thank you!
You can use 5G on GOMO with pixel 6.Hi All,
Thanks.
Then where to buy 6? Sad..
Apple pixel 6 ? This is test model that’s yet to be released!
