Super Glue - bought about few months back hardened
edmwperson
Unused not opened kept in cool dry place.. whole tube hardened
cannot buy such stuff keep for just in case use
Sausage
it will always harden in the tube
u only buy what u can finis in 3 months
always got gongsters who think in the tube will last forever then they buy 600 tube from abc discount store
Read HWZ Forum Rules!
li9ht5peed
my loctite 480 was bought 6-7 yrs ago. still liquid when last used a few weeks ago
i also have made in china gel type instant glue. after 2 years still liquid inside
how do u tell if the glue will harden inside? check for metal tubes that are sealed and must be pierced
my super glue brand new only screw shut. nothing to pierce because it won't harden unless you leave it open for a long time
Dracky
Depends on type of glue. The quick dry cyanoacrylate type will have short shelf life.
edmwperson
Kept in fridge?
li9ht5peed
Kept in fridge?
loctite mostly kept in fridge, but i've left it at room temperature for days recently without hardening
the china instant glue is always kept at room temperature, and never hardened
sunsetbay
Moderator
Moderator
Buy new one, $1 only~ :s22:
li9ht5peed
for tin, use soldering
for copper, use brazing
for iron, use welding
for wood & paper, use super glue
for filling holes in wood, use epoxy
for filling shallow holes in walls, use putty
for foam & rubber, use dunlop gp glue. if it's a shoe sole, clamps must be used, else won't work
