Apple Watch Series 4 side button
yeowboon
Anyone experience before Apple Watch side button spoil? I think my button because was about to use apple pay by double press the side button and realised it didn’t show up..
reddevil0728
it's not unusual that such mechanical part can malfunction.
is there still tactile feel?
have you tried to restart?
yeowboon
Yes the touch is still there, but when press no response. I did a full reset but the problem is still there..can’t restart because that’s the button to on/off the watch..
reddevil0728
then bring to apple store to get it diagnosed if it is indeed the case.
anyway what's your intention to ask if others experienced it before? is there like a 2nd part to that qns?
我要买GTR
If physical button faulty then most likely it's time already. Never heard before physical button faulty linked to OS. Don't think it's wise to repair too since Apple watches are usually not very repair friendly. Considering the price, can consider an SE if you are not looking to splurge.
reddevil0728
if go to apple their "repair" is replace
jq75
this worked for me.. these days i start to have this habit.
shut down phone via the side button before charging.. helps to keep the button moving in case, dirt trap, sweat etc corrode the edges of the button
https://www.switchingtomac.com/appl...arm Running Water,to achieve the same result.
How do I unstick the side button on my Apple Watch?
Warm Running Water. If a single drop of water doesn't do the trick, you can try running warm water over the watch button while pressing it repeatedly to achieve the same result.
yeowboon
Thanks a lot for the tips! But i think really cannot liao, button can press but no response..
jq75
Slowly. If u are making progress. try pressing button towards each end a few times, press middle section.. if press and hold see if there’s any respond
watch always come in contact with moisture?
