Yes the touch is still there, but when press no response. I did a full reset but the problem is still there..can’t restart because that’s the button to on/off the watch..it's not unusual that such mechanical part can malfunction.
is there still tactile feel?
have you tried to restart?
then bring to apple store to get it diagnosed if it is indeed the case.Yes the touch is still there, but when press no response. I did a full reset but the problem is still there..can’t restart because that’s the button to on/off the watch..
if go to apple their "repair" is replaceIf physical button faulty then most likely it's time already. Never heard before physical button faulty linked to OS. Don't think it's wise to repair too since Apple watches are usually not very repair friendly. Considering the price, can consider an SE if you are not looking to splurge.
but this happened AFTER you updated to the latest iOS version?Thought if it is a bug in current OS.
this worked for me.. these days i start to have this habit.Anyone experience before Apple Watch side button spoil? I think my button because was about to use apple pay by double press the side button and realised it didn’t show up..
Thanks a lot for the tips! But i think really cannot liao, button can press but no response..this worked for me.. these days i start to have this habit.
shut down phone via the side button before charging.. helps to keep the button moving in case, dirt trap, sweat etc corrode the edges of the button
https://www.switchingtomac.com/appl...arm Running Water,to achieve the same result.
How do I unstick the side button on my Apple Watch?
Warm Running Water. If a single drop of water doesn't do the trick, you can try running warm water over the watch button while pressing it repeatedly to achieve the same result.
Slowly. If u are making progress. try pressing button towards each end a few times, press middle section.. if press and hold see if there’s any respondThanks a lot for the tips! But i think really cannot liao, button can press but no response..
