5G router any1?
hwzlite
https://www.cnx-software.com/2023/0...-review-part-1-specs-unboxing-and-first-boot/
TanKianW
Most of the time, a 4G router will work just fine. 4G mobile phones might not be practical for an office setting with multiple network devices and appliances running/connecting at the same time.
Deployed a few for off-site (container/temp) offices w/o fiber TP, but still subjected to the mobile reception.​
Lss
im using d-link DWR-961 at home but sometimes can be sluggish and no wifi antenna so coverage not great. only up side is cheap. anything that i can change to that doesnt break the bank?
clyp1973
I received the GL inet yesterday.
I am very happy with it, comes with 2 sim slots, 1 TF...whole lot of antennas
Build quality is plastic but well constructed.
I ordered my 5g sim from circles life, activated the sim via my phone. Then I insert the sim into the GL inet router.
Switched on and use my phone to access the router admin page, only set password and which band (5g or 4g) to activate.
Overall very compact and easy to use. I will bring this on trips definitely
Bear in mind, this is NOT for on the go as you need to power this with a powerplug. Maybe for hotel room or something
clyp1973
It says pre order... But I still receive it .. not sure why the webpage still show as pre order
TanKianW
The setup for the GL.iNet routers should be quite similar.
Feel free to check out some of the more advanced configuration HERE
clyp1973
Been using the unit for more than a week now . I am very surprise how good the 5G reception and broadcast of wifi to my equipment..
I been using this unit in my office whole day today, link up 3 devices at the same time, windows, iOS and Android all together.. very good speed and stable
keenklee
IMHO.
If have time to test, what is the speedtest like vs 5G on the mobile ?
