hi, i'm looking for guidance for a new rig. the rig is mainly used for casual gaming CS2, D4 and infotainment.
Monitor currently AOC Q2GS 27" , 2k QHQ 165Hz 1ms G-SYNC monitor. i just bought this for connecting my work laptop for extra screen and will be using this for the new rig. so requirement will be 2k gaming for now and maybe upgrade to 4k in future.
i referred to the entry and mid range and and thought i might need a rig between 1.5-2.5k and is looking for advise.
MOBO+CPU (required wifi, bluetooth, and optimize for GPU. DDR5 for future proof. MATX should be enough)
HDD/SSD - one drive sufficient for now
RAM - DDR5 16 or 32GB
GPU - since monitor is G-sync only, am looking at nvidia maybe 4070 or 4070ti, any big difference between the 2?
PSU - to be able to support the combo healthy in the long run
Windows - required
casing - no specific requirement, but if its those open glass would be nice too.
cooling - any special requirement for water or air cooling to keep the rig cool.
lastly, any shop or bro can that i can get one stop with assembly and cables management?
IT show is around the corner end of the month, will there be promos for DIY building worth waiting for?
thanks to all the pros in advance for the advise.
Windows - required
