Xiaomi 13 series
Computeron
how much can you save lol. after the global come out at 30% higher price everyone will rush to the import version
even global out I don't think will buy liao... ip15 around the corner liao...
not worth buy CN now, unless 2nd hand cheaper or stack coupons till cheap in shopee
plustwo
anyone knows where to buy the original fast charger? the ones i get from shopee always stop charging fast after a few weeks
limmk
https://www.ithome.com/0/693/946.htm
vaxvms
apple users normally will not chg brand one even they see and look n review other even better spec phone
cos is too easy to migrate from old apple to new apple
me only fruitty is ipad
seansin
My exp with Poco is that most local bank apps are ok with unlocked bootlaoder, but not overseas one. But local Trust bank app has issues too with unlocked bootloader
What is the issue with Trust app? Cannot start?
I don't have Trust account. But i installed the Trust app and it works all the way through the page where you can apply for its credit card or saving account.
caterham7
wah damn ex sia the 120w. anyone bought before? will spoil easily or not?
note: xiaomi 13 67w charging, xiaomi 13 pro then is 120w charging
tbh, not worth it for the price
multi-port GAN charger cheaper
plustwo
mine 13u 90w. gan charger can hit the same speed as official charger? because so far i haven't found any non official charger that can really charge fast. some of them show the turbo charge screen but the battery percentage increase like snail
caterham7
cannot hit same speed. cos xiaomi using proprietary charging standard
tckrto
Can just go taobao buy directly from Xiaomi and ship back. The socket can be solved by buying those conversations plug or buy international socket extension to use.
SE4N23
Seems like telco ran out of Xiaomi 13 Pro, both starhub and singtel no stock, m1 only has 256 for black model, anyone know why or just got to buy from xiaomi without line.
