Xiaomi 13 series
sam39sg
:s12::s12::s12:
Oktechie
any one has good experiences with china rom? I used a 11 and 12 ultra china rom and it was wonderful for a while and then later on all the delayed notification, tried the fix doesn't work, banking apps started to have issues months into it. Sold it. Also apps don't get fast updates to dl on the china rom
Was wondering did anything change since? kindly do share thanks!
hkchew03
No issue so far with notification, but I think there is bug with light up notification on MIUI14. App still update frequently thru google play. Many of the notification issue can be solved with autostart/battery saver option.
Computeron
I had the 11u... no issue..
now I think no OS update liao right? my patch is still last yr dec.
Oktechie
Thanks. I was very frustrated because i had no other phones but Xiaomi and the banking apps would not load. just empty screen (DBS, SC, POSB) along with delayed notifications so i had no choice but to buy some other phone. I do miss the display and the cameras very much as well as the touch sampling. There just isn't any like it....and i have tried a number of flagship usual mainstream. I do wonder why people don't bother with this.. is it the "non atas" branding? :p
Does ANYONE only have xiaomi as their main phone (enough confidence?)
Computeron
don't talk about ROM N APPS....
to most Xiaomi is a china n budget brand. even u tell them 13u is the flagship... they will said $8xx?
xiaomi just can't beat other domestic brands in SG. I think xiaomi also lose to OPPO in SG.
if ur colleges saw ur new phone is iPhone or Sammy new series... they sure say AI SEI...... RICH SIA...
see 13U... HUH.... HAO YONG MAH?
Oktechie
perhaps its only me but when i got the iphone 14 pro max i saw the "slowness" of the touch sampling and had to hurry to sell it before the price drops by the day. so Xiaomi phone is really fast and you are RIGHT!!!! they will HUH? how much? crazy and will not bother (which then is a problem in the secondary market, very small and lose so much value) . I'm also considering pixel phones, the camera is so GOOD but...dropped calls, wifi drops aiyah , heat from tensor, all so troublesome.
but i'm at that age that i dont care to impress ANYONE, let alone colleagues who also have to work for a living :p
I just wish to hear enough positive experiences for people who have used it for a long while because my problems only started after about half year....
Computeron
I think delays notifications got fix... from ez ones like allow this n that + lock it.. (got ppl even said delay notifications doesn't exist anymore.)
extreme method - flash EU
banks apps.... I dunno about the fix... as my 11u no problem... n those with no issue also will say theirs is fine... just u only...
if comes to this stage, n can't find anymore solution then is time to sell liao...
andyhtc
Suspended
I am using K50 Ultra and have not encountered these delayed notification issues.
ZhuTou!
I have been using xm as main phone for years. There is always a fix to the lag notification. U just need to do the setting. If it doesnt work well, use the adb method. Then last option flash to EU rom. Banking app etc all along no issue even before 11u.
tckrto
You mean Monmar? I don’t know; am waiting for another China phone from them. Been 8 days and still waiting. Some of the other shops same price and had ready stock for 13u so I went with another one also ordering 12 months warranty for “non human damage”.
If u need google one, android auto, google assistant to work. Then gotta flash to Xiaomi eu custom ROM.
Oktechie
Thank you
Computeron,​
andyhtc,​
ZhuTou!
For your replies (y)
i did a search, but was unable to find where people install curved screen protector on the 13 ultra xiaomi, and anyone want to guess global price for SG? :)
bertrande
Thank you
Computeron,​
andyhtc,​
ZhuTou!
I just bought one from TB and installed it. Had to follow a video guide and then had to curve it at the sides but it works and it's super private. Not cheap by TB standards but pleased with it. Fingerprint detection also not affected.
Oktechie
this is beyond me.. :cry: i can't do this well at all
Dahawk
Anyone has issue with wireless android auto?
Cant seem to connect.
Local set xm13pro
