[new] Heya.sg
pigpigoink
IMHO.
Got set airplane mode ? :ROFLMAO:
Maybe I paranoid that mobile not connected may lose SMS. :ROFLMAO:
I got one mobile with Heya, always off - seems not getting SMS for the reminders and top-up.
Have not investigate yet. :ROFLMAO:
main line, cannot airplane mode also la :ROFLMAO:
anyway even if airplane/off a while, sms should still be there as telco sms server will keep the sms for a while if not wrong.
keenklee
IMHO.
That is what I think also.... until I got Heya.SG. :ROFLMAO: But must investigate first. :ROFLMAO:
pigpigoink
standing opposite jcube bus stop. can say it's quite crowded with people. loading a pictue in edmw thread is slow.
just sharing.
keenklee
Zym or heya better?
IMHO.
In my testing side by side, seems that for download, Heya.SG have "higher priority" than Zym.
Upload speed, Zym is higher.
Heya.SG has VoLTE ( have not tested ).
Zym have roaming.
Tedicious
IMHO.
Zym have roaming.
Zym dont have voLTE?
Revolee993
IMHO.
Zym have roaming.
Heya supports VoLTE? Is there a device compatibility list? That's a first non-gomo ST MVNO I've heard that supports this infrastructure iirc.
keenklee
IMHO.
IIRC, the support for VoLTe was there since they launch in May 2022. There is no compatibility list so far. For me, it just works for my devices e.g. 2019 old Samsung or 2023 new Samsung.
tszkitc
Just checked Heya app. Data,call anf sms valid till 25 June but Base plan only valid till 20 June. My question is when should I do the top up?? Thanks.
keenklee
IMHO.
Data/Call/SMS is your Heya Plan. When you top-up at expiry i.e. 25 June, the unused will be rolled over.
Base Plan is like your insurance - If the Heya Plan expire, you still can retain your mobile number.
By right, when you renew your Heya Plan, the Base Plan should auto renew for 60 days at the same time. :unsure:
Tedicious
IMHO.
If i dont top up, does it means that after 60 days the line will be cut off?
sango65
Suggest you dial *119# and see the sms to check the validity dates, seems weird that base plan's validity is earlier than data, call and sms
Tedicious
IMHO.
On paper yes.
Ok just cfm with CSO (hopefully their info is right), 60th day line will be suspended if you never top up for the plan and you have a grace period of another 30 days for the line to automatically terminated.
