Sony Xperia 1 V
tarui04
If I insert sg sim card into a hk set xperia and use roaming will it show volte on a hk set?
GeSteSoh
X1V display demo avail at 313 :) o_O :LOL:
Qubicfactor
That's not how the low light exhibit should be used. Should put the cam right up to the little dark room. You take from far will still be dark coz washed out by the external light so can't see the low light improvement
GeSteSoh
Yeah was trying to see if there was any "AI smartness" when it came to recognizing a dark room area :LOL: :) ;)
GeSteSoh
X1iii left vs X1V right
Relief at least the sharpness is performing better than the X1iii. :LOL:
chooyoshi
Wow, it will be in the smaller model, not 1V.
And not sure if what are the downgrades on the 5V like we had seen in the previous generations.
Mixed feelings about this you know. :spin:
SG only sells 5 in one colour
Not likely to be this one
darkmatt
I think that is reasonable for X5 series. But to get it for that price or lower, either an export set or wait for few months for sale prices.
whats the difference between 5 and 1 anw.. just size right?
rssd21
Aside from the physical size and screen resolution, the IV generation have differences of the memory storage (highest - 512 vs 256 GB) and camera modules. Earlier 5 series were lacking wireless charging
Toader
Nope. Different lenses as well. Likely for 5 series sure either less ram or different focal length. Will not overpower xperia 1 series. Processor benchmark scores and photo quality will also lose out by a tiny bit ( pixel peep to see the difference)
But sometimes the 5 series are more stable because most of the bugs ironed out in 1 series and they imported the solution / improvements over .
chooyoshi
That is another sad truth. I would buy export set if it is really attractive though. :s13:
Personally this doesn't really matter since a case can always be used to give a new color
Also Sony has a 15 months warranty - 12+3 when registered online
