Singpass App on Custom ROMs
Hi1307
I haven't had issues with SingPass on Pixel Experience in quite long, last version with issues was back in 2021. 18.1.1 still works well.
Hi1307
Unlocked bootloader? Magisk? Denylist? Shamiko?
Of course bootloader must unlock to flash any ROM.
Works without root, and with root (Magisk + Zygisk, hide GMS and SingPass). Haven't used Xposed/Lsposed in years.
LaughLoaf
Forced update to 18.1.1 detects root. Magisk + Shamiko Blacklist + Universal Safetynet Fix Displax, no longer works to hide root, App will force exit with error message: "Something went wrong".
Using Fdroid App Manager, disabling Service "o.bMN" and Providers "o.EE" stops the error from occuring, but crashes upon trying to access any service.
****ing Govtech really trying their hardest to shut down root users for good...
spinning_quirK
How do you figure out which of those o.* activities/services/receivers/providers to disable?
spinning_quirK
Singpass is detecting something that even Ruru and Key Attestation don't. Need a pro to figure out what it is.
IOKNEE
OCBC app on my phone tripped, but I'm not sure if I messed up something or because of LSPosed or just OCBC improved their app. My DBS, GPay, ActiveSG, Healthy365 are still ok.
Do you guys have any issue with OCBC app?
spinning_quirK
Are you using HMA on LSPosed?
IOKNEE
I've been using LSPosed for many years without issue, but just recently OCBC app tripped, so I still consider LSPosed a possibility. I just want to check if anyone here could get OCBC app working with LSPosed.
LaughLoaf
Temporary Workaround for Singpass:
- Uninstall 18.1.1, downgrade to 16.2.1
- Make sure Magisk 26.1, Shamiko 0.7.3 (174), Universal SafetyNet Fix v2.4.0-MOD_1.3 Displax MOD and FDroid App Manager are installed
- Enable Zygisk, Add Singpass to Denylist (Do not enable Enforce Denylist)
- In App Manager, disable the following:
Services: o.bMe, o.DN, o.IM, o.Jw, sg.ndi.push.service.FcmListenerService
Providers: o.EZ, o.sN
- Clear all Singpass App Data under App Settings
- Reboot
This gets rid of the forced update popup. Singpass Secure Token setup works, and able to access all services without problems.
Not sure how long this will continue to work though. They may eventually stop allowing older app versions from accessing the service.
kediraksith
- Reboot
sibei pro
Update: on delta, no modules, zygisk enabled, hide enabled, enforce sulist enabled.
followed your fdroid app manager settings. works like charm.
yoongdeer
- Reboot
thanks so much it works!! ur a legend
IOKNEE
- Reboot
I followed the steps above except for:
  • I didn't clear Singpass app data.
  • I didn't disable sg.ndi.push.service.FcmListenerService
  • I have LSPosed
Singpass app 16.2.1 can be opened without force updating prompt, but there's a minor side effect that Singpass app notification is broken (likely due to some disabled services above to bypass the updating prompt).
kediraksith
sometimes im not sure if we should post all these... those scums prolly looking at this thread and is making counter measures right now.
