kelvinti
So, to me personally, I have decided to continue with SIMBA $10 Plan. :devilish:
I will instruct VIVIFI to cancel my $10 VIVIFIVIVE after fulfilling the 2 cycles of billings. 🍥
anthonygreenisreal
I also feel like porting to SIMBA. Coz can go kaki bukit there and do. Do you know they do porting during weekends?
kelvinti
GO! Go ! Go ! :devilish:
1 Kaki Bukit View, #02-10 Techview, S415941 (take exit A at Kaki Bukit station, and walk towards lobby B)
or Basement at PLQ.
Okay. Based on SIMBA's webby and my experience.
Porting process takes place during the weekdays between 11pm-1150pm only and provided that you collected and activated your sim card before 630pm on weekdays.
However, some people did say that SIMBA port-in does happen over the weekends. To be safe, do it during weekdays.
So, basically, if you go to collect and activated your sim card over the counter now. The porting process should happen tonight unless they cocked up!
Jurong640
you can try. I opted for eSIM, I don't need to wait and travel down to collect SIM Card. Some more all configurations, APN settings are done automatically. Roam is ready right after SIM activation.
Had previously collected SIM card before many years back. Now my line uses eSIM
anthonygreenisreal
or Basement at PLQ.
Can check with you guys if porting over from Heya, do I select SingTel ? Coz there is no heya in the drop down option. Closest is SingTel
tohchr
Well, after using both SIMBA and VIVIFIVIBE for the past 3 weeks.
Based on outdoor usage. Even though vivifi has a much faster speed but it doesn't transform into faster and smoother loaidng of YouTube and Facebook and etc apps.
Somehow, SIMBA, with its lower SPEED can load apps faster and smoother.
Both are 4G+ at those moment.
Strange indeed
So, to me. SIMBA still a overwhole winner in such day to day mobile apps usages.
Let's not talk about downloading and uploading of files. In those those scenario. Faster speed of vivify has an edge for sure. However, we don't really download and upload many on mobile.
Bookmarked.. See when u porter again!
kelvinti
If anyone still has doubt about SIMBA. :)
Look at this speed test result. They are more than enough speed for mobile apps in most places! :cool:
This one was taken in a CBD area.
kelvinti
SLE Lentor exit. Now simba upload speed getting better
26.7 of Upload speed!
That's insanely awesome.
My friend who just gotten simba a few days ago told me that, out of all places. The simba speed around Changi North Way area was super good too.
kelvinti
Simba have to imrove their 4G connection, otherwise it's very usable.
True true!
However, the matter of fact is that ST is so bad at my house. Totally no signal sitting at the dinning table and very unstable connection at my balcony. Lol..
