Advice needed for PC Rig build
zohn1999
Main use is for lightroom photo processing.
I will need
Good CPU
32 GB RAM
1 or 2 TB SSD
Entry or Average GPU
24 to 27 inch monitor
Using windows
Using lightroom mainly. Casual hobbyist
Full ATX is preferred. As I believe better for system overall. Air and heat.
Ok for microATX
Added: budget $1,500
Thank you.
NightRaven49
I will need
Good CPU
32 GB RAM
1 or 2 TB SSD
Using windows
Ok for microATX
lightroom leans mainly on cpu, and hardly uses gpu. the performance uplift when using a midrange to high end card like the 3080 is only around 10%, so id say its better off to maximise budget on cpu and run off integrated/cheap dedicated graphics. speaking of which, what is ur budget?
poooooo
13600k more than enough, LR don't really need multicore, just need a fast single core.
zohn1999
Thanks. Budget 1,500
NightRaven49
plenty of money to play with, assuming budget is for pc only.
cpu + mobocore i7 13700 + gigabyte b760m aorus elite ax d5831fuwell
coolerthermalright peerless assassin 120 *157mm height57tradepac
ramgskill ripjaws s5 2x 16gb 5600mhz ddr5145bizgram
ssdwd black sn850x 1tb130tradepac
psunzxt c650 gold130tradepac
with a $150 budget for a m/atx case of ur choice, total is up to $1443. if need to accommodate monitor, i would change the above to the following:
cpu + moboryzen 5 7600 + asus tuf gaming b650m plus wifi589 (574 + 15 for combo only)dynacore
ramgskill flare x5 2x 16gb 5600mhz ddr5 expo145bizgram
u can also even drop the cooler, as ryzen non x parts sip power and the box cooler is generally adequate. this would give u about $300-350 for a decent 27" monitor.
zohn1999
core i7 13700 + gigabyte b760m aorus elite ax d5833tradepac
with a $150 budget for a m/atx case of ur choice, total is up to $1445. if need to accommodate monitor, can swap to a ryzen 5 7600 + asus tuf gaming b650m plus wifi at $589 from dynacore and possibly even drop the cooler. this would give u about $300 to play with for a decent 27" monitor.
What would the cooler help with?
Not playing games
zohn1999
quiet operation with low cpu temps. intel stock cooler is not that great, especially for a power hungry cpu like the 13700.
is there any computer case that will work with thermalright peerless assassin 120 *157mm height? how can I check the height?
zohn1999
cpu + mobocore i7 13600K + gigabyte b760m aorus elite ax d5720Dynacore
coolerthermalright peerless assassin 120 *157mm height60Dynacore
ramgskill ripjaws s5 2x 16gb 6400mhz ddr5180Dynacore
ssdwd black sn850x 2tb235Dynacore
psuseasonic focus GX 750 gold168Dynacore
GPUGigabyte 3060 12 GB450Dynacore
caseLian Li Lancool 216126Dynacore
TOTAL1939
currently looking at this.
koohansen
TOTAL1939
You can easily double your RAM if you don't mind buying from Amazon
https://www.amazon.sg/Vengeance-Optimized-Ten-Zone-Lighting-Regulation/dp/B0BPL82FD9
NightRaven49
TOTAL1939
as mentioned before, getting a dedicated gpu wont boost performance much in lightroom and would be a waste as u are not gaming. id rather spend less extra money (~$110) on getting the faster 13700. id also go for the asus rog strix 750w (which is basically a rebranded focus) if it is in stock or msi mpg a750gf, both under $150.
thats the same capacity, but u lose local warranty support.
poooooo
Not playing games
Actually these software like blender or hitfilm, when doing rendering or encoding will stress the cpu even more than gaming, my 12700 playing cyberpunk only 65+C, but rendering for blender hits 75+C. That is with arctic lf 280 aio.
LR normal operation won't stress your cpu that much, but during exports if you have a lot of files, that is one of the time it will stress your cpu as it will use those 8 cores available.
zohn1999
Thanks for the information
