Lenovo Y700 tablet
RRSS128
Anyone bought Lenovo Y700 tablet? I contacted Lenovo but they say they don't have this model and directed me to Shopee.
How's the performance and easy to use or not?
Teo Ming Ern
Seriously??? Direct you to grey import sellers? Or they only sell this tablet via their official online store on the Shopee app?
Dorkable
Coz Lenovo did not release any Global Legion Y700. It's a China exclusive.
caterham7
I see a couple of seller, got global version and China version but I don't understand the difference.
as mentioned by someone earlier, y700 not sold officially locally
meaning the listings u see, all are export sets, no warranty
if u do not understand the difference, suggest not to purchase
there are different workarounds that u have to deal with
Teo Ming Ern
The Y700 is available in Europe and US... so these regions use the global ROM...
The Y700 that is sold in China uses the China ROM...
Differences:
1. The global ROM supports the full Google Suite of services including the Play Store and all associated DRMs out of the box... the China ROM also supports the same but you have to install it yourself - you don't have access the Play Store on boot up, so you have to download the files separately and transfer using a USB flash drive (also known as sideloading)
2. While widevine L1 is likely supported on the China ROM, it doesn't mean you will get full HD + 4K play back for Western streaming sites like Netflix... the device has to be registered and lodged with Netflix.
3. The China ROM only has 2 languages - Chinese & English. Choosing English will change the interface to English but some deeper parts of the menus or system may still be in Chinese.
4. The China ROM comes with lots of China centric apps - most can be deleted but some can't and can only be disabled. This takes up space and with storage so little and apps taking up so much space these days, may be significant for some and not for others.
5. Updates of the China ROM may require you to use a China VPN to allow the servers to check your location as China in order to allow the update... this seems to be part of Lenovo's plan to segregate the market properly. Cos it is possible in the past to buy the much cheaper China version of Lenovo tablets and flash them easily to the global ROM thereby saving substantially off the list price. Right now it's not possible to reliably flash the global ROM on a China version Lenovo tablet. No one has been able to break the encryption or figure out what the security handshake is like.
6. The whole user interface doesn't look like Android... it's their own local China skin on the China ROM - it is likely a fork of the standard Android ROM for whichever version is installed... so it may present issues for certain apps and functionalities for niche apps...
Bottomline - if you're just living off web apps and streaming from the web through browser - you can relax and buy the China ROM version. If not, get the global ROM version and pay the premium for all the licenses that the other version doesn't have...
RRSS128
Differences:
Thanks for this detailed info. I am seriously considering this model as the specs look ok and its small.
Racking2322
Differences:
the sellers i ask seem to be saying global rom cannot update. know of any seller of the proper global rom? Can pm me thnx
Teo Ming Ern
Then they're likely not selling the true gmjaaj ROM... it is some fake ROM they mod to look like the global ROM but it cannot be updated... in that case just buy the China ROM version if all you want is to play games or watching web videos...
Racking2322
Only issue is can't find sellers for real global rom. China rom also no point cos i hope to do more with the tab
xonix
AFAIK, y700 tablet was never officially launched outside of China. The y700 you see on Lenovo eu or us websites is a windows laptop. I bought one from shopee, played with it and sold it after 6 months because of low usage.
RRSS128
Just when I am ready to place order for this tablet, the 2023 version is launched 🫥. Now I am undecided again. The price difference is about $100. A bit faster though and 2 type c ports.
Better to get the 2022 or 2023 version?
Nekorin
I have the bigger sister y900. Does y700 2023 version dual USB C offer DP-in?
halocast
The only legit 8 inch android tablet.
Don't have any others already.
Wondering if they will ever global launch it :o
RRSS128
Not sure if there will be global launch. And most sellers in Shoppee offering wifi version only. No choose but hotspot from my mobile if i want to use outside.
ghgan1
Seem the 2023 version is using SD8 Gen1 cpu, not sure have heat mgt issue or not. I am using the old y700 for gaming, still the fastest among all the sub8inch android tablet.
