tohchr
It can be found in Google Playstore...so I presume it is ok.
Anyway not available in Playstore for my "newer" phone.
I can still find it in PlayStore using S23U.. Is S23U considered "newer" phone?
Maybe you wanna try "TPG-Lity".. Must include the dash " - "
hwsstx
Strange hor...mine near 4 yrs old OPPO RenoZ.
Can you share the link from Playstore here. The link provided in the forum goes to Playstore but says for older Android. I did search but can't find in current Playstore.
tohchr
Thanks. Still...
"This app isn't available for your device because it was made for an older version of Android."
U got other android phones? Test and see if it's not available only on this particular phone?
tohchr
My Asus (ZE552KL) bought in 08Sep2016, can.
Android OS is version 08.
RenoZ's OS is 11.
Indeed strange.. Even newer OS/Phones like S23U can install and use. Maybe u wanna google for local apk for TPG-Lity?
Or if u use telegram, u wanna PM me your telegram @username and I see if I can send u the APK extracted from my phone.
hwsstx
It's ok... Thanks.
I'll just have to live with getting SMS OTP & work with SIMBA to improve their accounts :)
tohchr
It's ok... Thanks.
Anyway, it's more accurate using the SIMBA app then TPG-Lity (Super Roam 50 is not reflecting correctly) and the sms authentication is not longer required every time now. Just suka suka occasionally required sms.
SongManKranji
High Honorary Member
Hi I am trying to call this no using simba. Got 100mins idd call. Is this the right way to call
Life is v short. Ai song song kao tuas & Changi.
tohchr
Tried a few times but it just hung up after few seconds.
I suspect your number still short of 1 number. I tried to call that number u posted, it will not go thru.
I tried calling my JB colleague number, can go thru.
Edit: I just check with my JB colleague, she mentioned that your number is still short of 1-2 numbers. Depending on which telco does that number belongs to, should need to have example, 14 , 17 , 18 etc after the +60.. U need to find out the full number as the number you provided is definitely still short. (This is what she told me)
So the number must be similar to +60 xx 7 336 3486 (Just an example) Maybe those from our neighbours can help to correct me.
SongManKranji
that no is xiaomi at mid valley. I got it fr website. 😁
