Xiaomi 13 series
Milo-Dino
Guys who wanna order on Lazada, should get from this store..
This is singapore xiaomi...
*this same confusion was also there when xiaomi 13 pro released
TechNuB
Not worth it when it comes with CN ROM.
Get from Malaysia if you can.
Not a bad idea if die die Wana get this 13 ultra.
Any idea what that free printer might sell for?
If can sell for a 100 bux.
1400ish for global set with 2 years warranty seems reasonable
caterham7
Android auto not even working on my local mi13pro
Interesting. I have heard anecdotal feedback that android auto can sometimes be iffy, maybe need to try another usb cable, or, for testing purposes, try another car, e.g. a friend or relative's car, just to narrow down the variables
Livewings
Can I ask u... if getting Xiaomi phones... is it better to not get the one with CN rom even tho u can save alot?
You will get compatibility issues with a lot of apps even though technically you can install Google Play Store. There’s no guarantee all your apps will work.
Livewings
Tbh, I’m not sure.
I still recommend you get one from Malaysia instead.
8-lane
How about if the phone is CN set but flashed with global rom?
Livewings
Does it really matter though?
If your phone fails for any reason, you have just gotten yourself a $1300 paperweight.
When your phone is already that expensive, just spend a little bit more so you can feel safe.
8-lane
Oh no la... I'm not planning to get Xiaomi 13 series phone... only spending on a $250 - $300 phone... am deciding btw Realme 10 Pro+ and some other Xiaomi phones... locally I cannot find a Realme 10 Pro+ global set... only got flashed with global rom one... I'm not tech-savvy so i dunno what are the benefits of flashing a CN rom phone with global rom... wat r the benefits ar?
tckrto
Even buying local set doesn't mean local service center know how to fix it. Just go see the competency level u will know.
caterham7
Oh no la... I'm not planning to get Xiaomi 13 series phone... only spending on a $250 - $300 phone... am deciding btw Realme n Xiaomi... I'm not tech-savvy so i dunno what are the benefits of flashing a CN rom phone with global rom... wat r the benefits ar?
if u are not tech savvy, consider a model with local warranty, any issue, can go to service centre
there are no benefits of flashing a china rom phone with global rom, it is for some people who don't mind tinkering with their phones, and they get to have more choices, compared to the models sold officially locally
FYI, there is no need to flash rom, if you just want to install apps via google play. some china rom phone can work locally with google play store that is side-loaded, but sometimes there will be some limitations, and also in the past, issues of missed/delayed notifications
realme, not many models sold officially in singapore now, if u are considering, can consider travel to JB to buy, many realme models sold officially in malaysia, at least it will be global rom, and if there are any issues, still can got to service centre in malaysia
https://www.realme.com/my/
FYI, this is off-topic already, to discuss further, suggest u start another thread in the mobile sub-forum
last point, if u are not particular on a specific area/feature, for $300 budget, value-for-money choice is poco f4. this model EOL soon, u think some more, it will disappear from the poco shopee or poco lazada store soon
8-lane
I'm actually considering btw Realme 10 Pro+ and some other Xiaomi phones... Poco F4 is really bang for ur buck but for me, I dun really fancy flat-edged/flat back-and-front phones but it seems that all the new phones are now liddat... :(
