Xiaomi 13 series
tckrto
- Missed notifications, shouldn't be a problem now
- no issue with banking apps
- miui is known for ads, but can turn off
https://www.androidauthority.com/remove-ads-xiaomi-miui-1019139/- note: buying a global rom model doesn't guarantee 100% no problems, sometimes still may have software bugs
Think there's no more ad already.
But I using custom Xiaomi eu rom on mi 12s ultra so no such thing as ad pop up 😁
But seeing RWM pricing it makes me believe the price of Xiaomi is actually 良心价。
Is the distributor 没良心。
caterham7
FYI, sets sold to street shops are also provided by the same distributor
this is common to all brands
smart people wait for street pricing, before deciding which side got better deal
vibranze
Ads?! I thought those are because they are inbuilt in the apps instead of the phone firmware?
Ah I see, so only their apps ah, but since they have in memory apps, the pop up can come out out of nowhere iirc.
Good to know, thanks for the clarification
You need to unlock bootloader in order to flash other ROM, got issue with banking apps?
Thank you all.
progene
I like the charging stand.
Printer 🖨️ image below.
vibranze
Question: In terms of hardware, is there a difference between the CN and SG sets? I recall that the last time I used NFC, I had to select the correct option in order to use the paywave; is this still the case now? Isn't it cheaper to buy the CN set if I'm going to flash the EU rom and don't need the warranty or freebies? Thanks.
Computeron
yes buy cn cheaper. more colorways n storage diff
but since sg already selling... might as well buy with a warranty... u can find deals w/o freebies...
vibranze
Is the filter ring only can be used with the Xiaomi special casing? Or it can be mounted directly on the phone without the casing? Thanks
superboey
yeah lens protector is probably good to put. Unless u r using the green case with the 67mm adapter and put on a UV filter.. for normal user i think overkill
