Temporary Workaround for Singpass:
- Uninstall 18.1.1, downgrade to 16.2.1
- Make sure Magisk 26.1, Shamiko 0.7.3 (174), Universal SafetyNet Fix v2.4.0-MOD_1.3 Displax MOD and FDroid App Manager are installed
- Enable Zygisk, Add Singpass to Denylist (Do not enable Enforce Denylist)
- In App Manager, disable the following:
Services: o.bMe, o.DN, o.IM, o.Jw, sg.ndi.push.service.FcmListenerService
Providers: o.EZ, o.sN
- Clear all Singpass App Data under App Settings
- Reboot
This gets rid of the forced update popup. Singpass Secure Token setup works, and able to access all services without problems.
Not sure how long this will continue to work though. They may eventually stop allowing older app versions from accessing the service.
