- Jul 14, 2005
我的血要喷完了。。。siang kar pager??![]()
If you are looking for screen comparison. I have seen a few chinese YouTube who does this.. compare all the 2023 flagship and compare their screen.... Perhaps, u would like to go and search for it.Don't forget Xiaomi also got issues before like tianma IPS screen ghost screen problem.
Problems like mi 8 wifi issue
Mi 11 series super hot sd888 issues.
Chronic failures that's shows not enough testing done before pushing product out.
Not trying to bash Xiaomi but their original path was listening to their fans and improve their products but it seems to be forgotten or forsaken over profitability.
Why mine do t have this watermark yet![]()
Tonight's moon is really bright and round. Having a tripod will be really cool with this phone. (should crank up the ISO and lower the shutterspeed so my shaky hands wun blur the pic, sigh)
Think unlike before now is possible to edit and input watermark after pic taken.Why mine do t have this watermark yet
There's an option in the camera app to add this watermark.Why mine do t have this watermark yet
To add on, you can readd watermark by going to gallery and edit photo option.There's an option in the camera app to add this watermark.
Mine is still the old typeThere's an option in the camera app to add this watermark.
Didn't see that option in gallery edit. Can only add watermark in cam app for me .To add on, you can readd watermark by going to gallery and edit photo option.
ah cool! thanks!edit > ai > art framing
yes..their microSD Endurance Pro cards are really good..otherwise..folks are forgetting the exploding Samsung Notes and battery issues.
https://www.gizmochina.com/2023/04/...e-reportedly-overheats-kills-8-year-old-girl/
I think case only in blackI pre-ordered and collected mine from Xiaomi Funan today … mine is Olive Green but how come the casing is black and not green ?
Thanks
The casing in box is all black.I pre-ordered and collected mine from Xiaomi Funan today … mine is Olive Green but how come the casing is black and not green ?
Thanks
Go to "pre-installed ringtone" and set to none for notifications?How do I turn off notification sounds except for calls?
