Xiaomi 13 series
Milo-Dino
Anyone having issues with the Simply Go app?
I could not enter the handphone number as it keeps crashing on my Xiaomi 13.
Emailed TransitLink and the usual advice to reinstall and clear the data.
No problem for my ultra
Synchroniza
Retiring from my p30 pro.. Bought the 13 pro. Tried the 13 ultra but find my hand placement awkward when holding on to the phone due to the huge camera. :(
hkchew03
I'm thinking... since the phone (xiaomi 13ultra) is so lopsided when we put on the table, would it be good to attach something like this to "balance" it up? It can double as a good stand too for "macro photography" hmm. Somemore today 7/7 sale.
Anyone has any experience with this type of magnetic snap ons?
eadd21af0164a602f8b7527b155b20c6
Actually on flat surface not so bad, just slight rocking, but phone remains perfectly tilted towards you. The magnetic snap on probably require a case with magsafe as well. And then next issue is if wireless charging still usable with a magsafe case + this snap on, both of which will add quite some weight.
SE4N23
Same, switched from mate 30 pro, the lens like very 'scary' using original casing. Like easily scratched.
Milo-Dino
see the other case I posted. Allows for lens cover and/or filter.
Oh cosz we were talking about original case.
Nilkin also has one with built in camera lens cover.
I still waiting to go China next month and buy hopefully the white kit
WJY
received the white kit from taobao official xiaomi store. look great and fits perfectly, just that the price tag is abit high at rmb 999
Nekorin
Yeah. For my case I don't use wireless charging so just a magsafe case + snap on should be alright? My concern is whether a snap on will affect nfc payment since I use the phone with simplygo.
Jun Jun
4 issues, speaker quality, selfie no 4k and auto focus, no uwb and no esim support. Their 13 pro have esim but using usb 2.0 unlike the 13u using usb 3.2 so...
Milo-Dino
anyone applied tempered glass screen protector?
As usual, does it affect the fingerprint scanning speed and accuracy by much?
hkchew03
Is anyone who bought XM13U bundle able to get 50w wireless charging frm the bundled 50w wireless charger?
50W wireless is like 90W wired charging, will only appear for short period when battery is at low % and low temp. This is provided you used correct charger and cable as well.
JAson1980
The Kit lens cover can be used on the black or camera case. I am using the cover on my black case ATM. while waiting for the nillkin case with lens cover.
