hwsstx
Collected liao.
Thanks for all the help.
Singtel, my previous Telco, has already cut me off (at about 11.05pm) but SIMBA hasn't turned on or ported over yet.
I've already set "TPG" for Name & APN.
Under "Carrier/Operator" still indicated as "No services"
VoLTE is already enabled.
Anything else I'm missing?
I presume SIMBA has to Enable for me to access SIMBA's network.
Thanks.
ekardo
Thanks.
you only have to wait..
tohchr
Thanks.
Around 1am
hwsstx
Thanks.
07.00am - started port-in process for 2 mobiles from Singtel to Seniors SIMBA
11.30am - collected SIMs
11.05pm - Singtel cut me off
01.11am - port-in successful!
Very fast!! 👍👏👏
... within 24 hours!
hwsstx
07.00am - started port-in process from Singtel to SIMBA
Very fast!! 👍👏👏
Yesterday when I applied online to port over to SIMBA, there was a place asking for a Password. I entered but I don't see it being asked anywhere, not by the app etc.
Do you know where it will be used?
Thanks
SongManKranji
High Honorary Member
Very fast!!
songz. I will port in another no soon. Will help my sil port over from singtel. 😁
Life is v short. Ai song song kao tuas & Changi.
tohchr
Thanks
When u used browser to login simba account.
acetylcholine
Anyone has any experience using the SIMBA 10GB roaming plan in the US? How is the connectivity and does it allow for mobile hotspot / tethering? The alternative is to go with the Celcom / DiGi roaming plan but it's more of a hassle to maintain a Malaysian SIM card, especially with the limited validity period. I am looking at the local US prepaid plans and they are so expensive so it really makes sense to rely on a foreign provider via data roaming.
ekardo
Can share details on the celcom Digi plan? Interested to see if it's worth getting
Jurong640
I think many pages back in this thread, someone shared his/her experience roaming in the United States of America. It is all seamless and no issues with data internet. Connectivity depends on their roaming partner. Their roaming partner is AT&T and T Mobile, both are establised network oeprators in USA, so don't worry.
Mobile Data hotspot is phone depending, not on simba side. You have to turn on hotspot sharing from your phone to share your internet while in Singapore or roaming. Cheers
zhiming1
Was in korea last week with simba 10gb roaming plan, unable to hotspot. Using Iphone 14pro.
Also, i find that the roaming data speed is not as good as local sim.
gaoqikai
as for hotspot, are you able to do it locally? If not, need to set APN for hotspot
ekardo
Were you able to hotspot before locally or other countries?
Iphone 12pro without any issue with Simba hotspot so far in msia, Indo.
acetylcholine
Can search for "Celcom Prepaid Roaming" on Google for more details - their website not very intuitive. If I am not wrong, it's RM98 for a 30-day unlimited pass which applies for 57 countries. Fair use policy of 2GB per day so it's probably more useful for heavy data users. Hassle is maintaining the line and it will be a waste if you don't travel to Malaysia frequently (to use the local data).
acetylcholine
Thanks! This is really helpful. So far I have been able to use hotspot sharing (on my Samsung phone) in Singapore and Malaysia so hopefully no issues. I have experienced certain travel SIM cards which disable the hotspot sharing function when you are roaming out of network, i.e. the function is completely disabled. Fingers crossed it doesn't apply to SIMBA roaming in USA.
lasnoblur
How SIMBA charge for receiving incoming overseas call ?
Same as IDD rates or different ?
lasnoblur
My port in process
Mon
8pm activated port in
Tue
530pm Paid off bills manually. (Mine is GIRO to be deducted at later date. )
11pm lost signal
wed
115am successfully ported in.
mubz96
Not good for me in the central eastern US. Couldn't connect to US telco with 2 different phones 4 mths ago. No issue with connecting to telco network of transit country in Europe.
