Xiaomi 13 series
filmlabkitt
50W max wireless charging only activated when screen is off.
In that case why does it say "30W MAX" when it is charging? Shouldn't it say "50W MAX"?
This issue is well documented here at www dot xiaomi.eu/community/threads/xiaomi-13-pro-wireless-charging-capped-at-30w.68448
So, has anyone actually seen "50W MAX" while wirelessly charging with the bundled 50W wireless charger?
JAson1980
i have seen 50W max on my Xiaomi wireless charger which i bought previously.
Haven't use the new one yet.
JAson1980
How do we get the free 6 months Google One and 3 months Youtube premium ah?
JAson1980
*Place your Xiaomi smartphone with Fast Wireless Charging on the wireless charging stand to start fast wireless charging. For best performance, fast wireless charging requires recommended with Xiaomi 67W and 120W Chargers .The power output can reach up to 50W with a Xiaomi 12 Pro or Xiaomi 12. *If using a protective case, the case thickness should not exceed 3mm. Please ensure that there are no metal objects between the wireless charging surface and the smartphone. We recommend Xiaomi smartphone official protective cases.*This product is Qi certified by the Wireless Power Consortium (WPC) to charge devices that are also certified by the Consortium. However, due to the differences between individual devices, some products may exhibit reduced charging efficiency. *All above data come from the Xiaomi Laboratory. However, data may vary due to objective environmental changes. Please refer to the actual values.
Nothing on power output on Xiaomi13 Phones
JAson1980
Thanks bro, but instead of buying online, does Xiaomi at Funan selling this ?
Thanks again
Bro i am not so sure. I got mine off Aliexpress, so far so good.
I have 2 xiaomi wireless charging stand. I can only get 30W max on the 13 ultra from the free one that came with the phone.
but when i put my Xiaomi 12 Pro on it. it can charge at 50W max.
My older xiaomi wireless charger can charge b\oth phones at 50W max. Both chargers tested with the 120W Xiaomi charger.
Weird
JAson1980
You are right, it charges the 13 ultra at 30W max. But the 12 Pro at 50W max. I have no idea why
tckrto
That's because of the camera bump that creates an air gap resistance between the phone and the charger. U need to use the new white wireless charger then can charge to 50w. Or try the old 80w white wireless charger.
【淘宝】https://m.tb.cn/h.5YZUm23?tk=wlw2dtoKrg2 CZ0001 「小米50W立式风冷无线充Pro」
点击链接直接打开 或者 淘宝搜索直接打开
JAson1980
2 Xiaomi Wireless charger powered by 120W Xiaomi Wall plug
White - 80W
Black - 50W
13 Ultra placed flushed against the 50W charging pad - 30W max
13 Ultra placed flushed against the 80W charging pad - 50W max
12 Pro placed flushed against the 50W charging pad - 50W max
12 Pro placed flushed against the 80W charging pad - 50W max
tckrto
@JAson1980 the position of the charging coil also is one of the cause to archive 50w charging.
Also the 100w car charger from what I found is that only when nothing connected to the usb-a port then the output to the wireless charger can hit 50w.
JAson1980
Yes i know, i tried all positioning to get the 13 ultra to charge it at 50W max but don't seem to be able to at least on the black wireless charger. Basically i have placed it at the optimal position with the closest proximity to the charger but still unable to get 50W wireless charging.
For the black charger, the lower portion is basically the exhaust port. the wireless charging pad is above the 50W wording. Honestly when Xiaomi made these wireless chargers, they did not expect themselves to produce such a huge camera on their phones. Basically the phone is dangling on the camera while placed on the wireless chargers. :s13:
tckrto
Profit first, consumer feedback not important.
caterham7
Thanks again
the 8 physical stores should have, depending on stock level
https://linktr.ee/EIN.sg
can buy online also, product link is to several models, please check and choose the correct wattage model
https://shopee.sg/Xiaomi-Charging-Combo-33W-67W-120W-i.237295326.18449898698https://www.lazada.sg/products/xiaomi-charging-combo-33w-67w-120w-i2474219643-s18502248580.html
price varies according to promo, check to see which side cheaper
Milo-Dino
U guys got change the screen protector?
I'm still thinking whether to replace with tempered glass
dreamcast18
nope..so far the current one is not as much of a dust magnet as the Realme GT2 Pro's factory protector.
only did the lens protector and now using the lens cap. As someone mentioned...very concerned about scratching the lens glass more than the screen. I think the screen using tempered, gel or factory protector is ok.
Milo-Dino
Seems like the original protector is thicker than most default protector.
Will use it abit longer and keep my tempered glass as spare
SE4N23
Not sure if it's because i'm too rough when replacing casing, side of original screen protector starts to have some small bubbles haha, Any recommended glass protector incase i need to change soon. Whitestone dont do for xiaomi.
Milo-Dino
I bought smart devil. Not cheap but supposedly reputable. Is curved though
