- Jul 5, 2001
Most important...Pen support on outer screen. No prob for fat fingers.amazing feat. so thin, and reasonably light. I wish they can cut the weight further by perhaps making the whole device smaller.
it's a bit odd to see a big 6+ inch screen on the outside and yet below 8 inch on the inside. the difference isn't that great to significantly want to use the inside screen. so over time I may just stick to using the outside screen most of the time while only using the inside screen for serious business like opening up excel spreadsheets, etc. which rarely happens.
but it's still a good device for probably those super multi-taskers who need to have more 'real estate' to view stuff on the go.
I guess for the normal consumer the flip phones (rather than folds) would make more sense for its greater portability at the end of the day.
Buy before it happensHonor gonna get sanctioned soon?
This are china rom. Wait for global rom. Normally a few months later.Price very expensive from shoppee
Global will not be cheaperThis are china rom. Wait for global rom. Normally a few months later.
Likely to be cheaper. Should be the same as Huawei x3. China price is 3000 to 4000 and Singapore set is 2598.Global will not be cheaper
if same price as samseng...worth it?Global will not be cheaper
Absolutelyif same price as samseng...worth it?
