DigDub
- May 21, 2002
Mine is XT2321-1.Your device model code is what? CN set model code XT2321-2.
I got my oneplus cyberpunk from them also. So far ok ah lolwah, u dare buy from the shop ah... heard they are the 黑店
Can use WhatsApp using the outside screen? Reviews shows outside screen can run all apps.Mine is XT2321-1.
Cannot...anyone know if can get the CN set to show the commute route to work on the front panel?
i think it uses the Motorola smart service app, but i couldn't get it to get my location
aww, never mind not something important. phone is still fun to use.Cannot...
Yup can. It can run almost any app you want on the external display. Even games.Can use WhatsApp using the outside screen? Reviews shows outside screen can run all apps.
1 physical sim and 1 esim.Can I also ask, for HK Set Razr Ultra 40, is it physical dual sim or 1 esim and 1 nanosim?
Try the flight widget. Is pretty good.aww, never mind not something important. phone is still fun to use.![]()
Jerry durability test.
Yup for a folding phone.Looks like a good pass on the "torture" test, very impressed
Out display crack due to the pressure of his thumb experting force.... Considered good pass?Yup for a folding phone.
It seems like the hollow part is near the hinge area where usually won't impact. Maybe to save weight or heat dissipation.Out display crack due to the pressure of his thumb experting force.... Considered good pass?
Wierd that it is hollow underneath with nothing supporting the front glass
Lol, I more chin chye, standard lowerOut display crack due to the pressure of his thumb experting force.... Considered good pass?
