Xiaomi 13 series
Synchroniza
Anyone on xiaomi 13 pro when seeing Google reviews and unable to open the photos in the reviews? It will be bugged out. Or is it MIUI issue? Thanks in advance
Milo-Dino
I just noticed that "atmos" kicks in when you open certain apps...
I was playing song on Spotify in background. But when I open youtube (without playing any video), the sound from Spotify suddenly gets louder and "enhanced"
Anyone noticed?
Milo-Dino
Anyone noticed?
Ok i noticed if you turn on immersive sound, Spotify gets enhanced.... Means youtube automatically forces "immersive sound" mode
dreamcast18
anyone knows where to get a lens cover that works with the 2 factory cases? Could only find this and cost about $20
Milo-Dino
By factory case, you mean the photography kit case as well?
If you are using a 67mm filter, I believe you can buy any of those dslr lens cap for 67mm lens
dreamcast18
yes the factory case and lens cover; but not using the filter; i have a 67mm lens cover - looking for one to replace the factory one..its smaller in diameter..
bertrande
My two month old China version 13 ultra out of the blue gave the dreaded “The system has been destroyed” message! Googling tells me it can be fixed via plugging into a PC etc. faint. I have never plugged this phone into a PC (photos backed up to Google photos) - anyone knows if there is another way of resetting the system?
andyhtc
Suspended
It could be a simple fix or require a change in the motherboard :oops:
I notice the prices have dropped by about $200+ from the launch prices.
bertrande
Thanks much - I did see it. The Shopee dropshipper I used asked me to contact them tomorrow morning as there is a tech guy there. Fingers crossed. Not too worried about data loss as it’s not my main phone and photos are backed up; just want the phone working again!
I don’t know what the local launch price was but I think I saw local seller selling for $1688. Still $300-400 more than PRC set through.
hkchew03
Likely software issue for 13 series, 11 series is more likely to get hardware damage due to the chip. But can only pray hard. As long as fastboot is accessible, there is hope :angel:
balzebub
Anyone know where to get nom curved tempered glass protector for 13 Ultra? Or curved ones that actually stays on and usable with cases.
bertrande
Going to send the phone back to China for repair. Apparently second set in short number of days that kena and fastboot not accessible.
chocoblitz
May I know which Shopee seller you bought the 13 Ultra from? Seems like they are pretty good at honoring the warranty.
