Singpass App on Custom ROMs
KeYoKe
Hi, just unlocked my bootloader, installed Magisk root, Singpass can't proceed further and get locked. What's the workaround to hide root? Tried Zygisk and SafetyNet module but same result. Any recommendation would be great. I can't disable the services and providers in App MAnager too, it said rules are not applied. Thanks.
Update: v16.2 being forced to to the latest version, couldn't find o.bMe, o.DN, o.IM, o.Jw but got o.bkk, o.DD, o.li, o.IR instead, disabled them in services and providers. After face verification, agreed to everything, it said something went wrong, try again later. (83-T991)
Anyone get YouTrip working? Thanks.
If your device has kernel su, i will highly recommend use that instead
KeYoKe
Thanks bro, it's a razr 40 ultra and im not sure got kernel su or not. YouTrip is working now, not sure what i did lol
Sometimes after enabling zygisk and after flashing safetynet fix module, will need another reboot even though u have rebooted once. Glad it has been fixed for u bro!
vibranze
YouTrip yes, but not Singpass, can I like downgrade it and disable some of the services to stop forcing upgrade to latest version? Thanks.
spinning_quirK
If you want to downgrade, you can get clean versions at apkmirror
Then to stop the upgrade forcing, you can follow the steps from one of the previous posts
vibranze
Yes, tried it but during the setup of the singpass it asked me to update and no other options, will try that again, weird that using the latest version of singpass i can passed the setup including face verification and agreed to everything, it said something went wrong, try again later. (83-T991).
U mean singpass? Disable playstore auto update?
I think my play store enable auto update is not checked by default but thanks for the suggestion, will make sure auto update is disabled.
LaughLoaf
Please see #145 on this thread. You have to apply the rules from the 3 dot menu at the top right.
Also make sure Shamiko is loaded and Singpass is added to denylist as well. Won't work without it.
vibranze
Thanks bro, got it now, I thought i need to freeze the app first which i did for singpass and it works, but for other apps like sgbusleh, it didnt but apply rules works :)
spinning_quirK
A dynamic freezing app will settle the issue.
I use Ice Box. Though I use it mainly to tame apps that suck phantom cpu power when even in the background, like the FairPrice app.
roidred
Magisk Delta (Canary) - 26105
Only Module installed - Shamiko v0.7.3 (174)
Custom ROM Android 13.
Singpass v19.0.1 works fine.
I have not even hidden renamed magisk package.
IOKNEE
so many variables but thanks for sharing anyway.
spinning_quirK
Why Delta Canary and not Stable? Does Stable fail?
Edit: thank you for sharing your experience, and no, Stable does not fail.
spinning_quirK
Are you on custom ROM? XPosed?
Custom ROM A13, no XPosed/LSPosed
Citibank works too
Based on XDA thread:
(I unhid TJW Magisk app, didn't do anything else.)
Then installed Magisk Delta APK. Then used it to Direct Install Magisk, though it said addon.d had some issue.
After reboot, removed TJW Magisk.
Added relevant apps to MagiskHide hidelist. All my modules, including Shamiko and USF MOD 1.2, are working. MagiskHide is not enabled, Shamiko is doing the job instead.
To resolve the addon.d issue I did a second Direct Install.
