tckrto
- Oct 21, 2001
Inside camera setting explore around.Anyway to disable the burst shot on the camera kit?
They only have black, Is it black sides frosted back?search for "xiaomi 13 ultra case dux ducis aimo" on shopee then see which one cheapest.
Yes, only one colour.They only have black, Is it black sides frosted back?
Ok i noticed if you turn on immersive sound, Spotify gets enhanced.... Means youtube automatically forces "immersive sound" modeI just noticed that "atmos" kicks in when you open certain apps...
I was playing song on Spotify in background. But when I open youtube (without playing any video), the sound from Spotify suddenly gets louder and "enhanced"
Anyone noticed?
By factory case, you mean the photography kit case as well?anyone knows where to get a lens cover that works with the 2 factory cases? Could only find this and cost about $20
yes the factory case and lens cover; but not using the filter; i have a 67mm lens cover - looking for one to replace the factory one..its smaller in diameter..By factory case, you mean the photography kit case as well?
If you are using a 67mm filter, I believe you can buy any of those dslr lens cap for 67mm lens
My two month old China version 13 ultra out of the blue gave the dreaded “The system has been destroyed” message! Googling tells me it can be fixed via plugging into a PC etc. faint. I have never plugged this phone into a PC (photos backed up to Google photos) - anyone knows if there is another way of resetting the system?
It could be a simple fix or require a change in the motherboard
I notice the prices have dropped by about $200+ from the launch prices.
Going to send the phone back to China for repair. Apparently second set in short number of days that kena and fastboot not accessible.Likely software issue for 13 series, 11 series is more likely to get hardware damage due to the chip. But can only pray hard. As long as fastboot is accessible, there is hope![]()
Did u flash to global rom? Or use as China rom?Going to send the phone back to China for repair. Apparently second set in short number of days that kena and fastboot not accessible.
Used as China ROM but downloaded GPS. I’m ok with China ROM as I use a lot of Chinese apps.Did u flash to global rom? Or use as China rom?
May I know which Shopee seller you bought the 13 Ultra from? Seems like they are pretty good at honoring the warranty.Going to send the phone back to China for repair. Apparently second set in short number of days that kena and fastboot not accessible.
Bought from MercuryTech. So far quite responsive. First purchase from them.May I know which Shopee seller you bought the 13 Ultra from? Seems like they are pretty good at honoring the warranty.
u lucky man... if other seller *COUGH*.. he sure tell u "Sir, pls wait patently for the new rom update."Bought from MercuryTech. So far quite responsive. First purchase from them.
