- Jul 5, 2001
Gotgot wireless charging?
sibei tempting...
Settings - gestures - wake display. Turn off moving the phone. If notification comes in, the screen will also wake up.Is there a way to disable auto-sensing on the external screen? I don't know what triggers it but it often turn on by itself, it's pretty annoying. Thanks
Yeah, like what I predict too after reading all the leaks, useless oversize widget screenAs expected flip 5 external screen is just an oversized widget screen.
Eh but from Dave2D initial review, it seems can use app on the external screen?As expected flip 5 external screen is just an oversized widget screen.
Heard good lock will be updated to support all apps on the external screen. But too bad the hardware limitation of 60hz refresh rate will still limit its appeal. Apps will also look smaller due to the smaller folder shaped design.Yeah, like what I predict too after reading all the leaks, useless oversize widget screen![]()
A few selected apps can be enabled under the labs option. Think have to wait for good lock to update them can use all the apps. But the 60hz refresh rate makes it not as appealing.Eh but from Dave2D initial review, it seems can use app on the external screen?
Ah i see, ban ban tan for all the apps to be updated in good lockA few selected apps can be enabled under the labs option. Think have to wait for good lock to update them can use all the apps. But the 60hz refresh rate makes it not as appealing.
^didn't work for me. I tried a slightly different way to flash eu rom (https://forum.xda-developers.com/t/no-razr-2022.4500499/page-3 form post #58). Relocked the bootloader for the eu rom successfully, but my software channel was retcn even though i changed it to reteu so that means i can't get OTA.Hello, I found this Moto Stock ROM website that have a CN stock ROM download, it will be useful if you are trying to revert to stock for resale, I downloaded it but haven't tried it out, Please update if you managed to revert to stock and relock bootoader using this rom. Thanks.![]()
Got volte on starhub on my HK global set.Anyway is everyone getting volte on their razrs?
Now that 3g is shutting down next year you better have it if you want to make phone calls
The crease after 2 weeks of use seems still the same. But since the phone has a useful external screen, so don't need to open so often. I estimate I use the phone about 70-80% using the external screen.Anyone with Taiwan or Australia sets? Hope to get 1 from these countries.
For bros that already have this phone, how's the crease after using for awhile. Does it get more noticeable?
Have not use foldable before, that's why asking.
Hi, do you mind to share the (almost) detail steps here, were you following the post from #59? I just realised my software channel is still RETCN, damn. If i do^didn't work for me. I tried a slightly different way to flash eu rom (https://forum.xda-developers.com/t/no-razr-2022.4500499/page-3 form post #58). Relocked the bootloader for the eu rom successfully, but my software channel was retcn even though i changed it to reteu so that means i can't get OTA.
I tried to go back to CN software the similar way i went to EU. Could load the CN software to use but if i relock the boot loader i would get the no OS error after relocking.
fastboot oem config carrier reteu
fastboot oem lock
I can see volte icon too on my CN set, I am on M1. Weird that when I was using Pixel 7 pro, there's no Volte, this make the zoom/teams conference using the phone so painful.Got
this is my first time using foldable phone too, the crease is okay for me, it's there but it didn't distract me at all, i believe crease wise, razr phone is still the best in the market, so just hoot lah bro hahaAnyone with Taiwan or Australia sets? Hope to get 1 from these countries.
