Water heater
luei74
My one place it at the laundry there, I "kay kiang" to mount the electric wire with tap on the tank surface, it burnt and my house tripped few weeks ago. The technician help to redo the wiring, and check the heater still functioning. So we still using it after the incident
bluethesky
Around 7 years old. Sensed slight dripping for about 1 month before it finally short circuited.
Likely the gasket of the heating element cracked, just like car engine cover gasket. Encountered same problem, just changed the heating element n thermal fuse problem solved.
vampire29
Hi, is there anyone install their water heater that can use hot water for kitchen as well?
daniel_83
saw a tiktok video that we are suppose to flush out the water from the storage heater every 6 months
the video shows alot of black water being drained out
is this applicable for SG? Mine prev water heater used for 10 years also never touch it.. before it died.
travbug
Hi, is champs a good brand for storage heaters? I initially placed an order for 707 storage heater, but vendor now say shipment delayed and if want stock now, suggest that i switch to champs slim storage heater (slb25). Is champ heater durability and reliability ok?
dodongdodong
Many stocks in shopee lazada
boombastick91
Need some advice from anyone here using storage heater with a bathtub - Wondering how big is your tank and if a 35L tank will be sufficient?
It will be a relatively small bathtub with total capacity of roughly 250L, think will only fill it up by half (100 - 120L) each time of use.
wacko
not enough, min 50L tank
Rivers
Hi Guys, looking for a instant shower that has pump feature to boost the pressure. Can anyone share which one of the 3 types (DC Pump, DC Inverter Pump, AC convertor) would increase the pressure most?
Thanks
