- Aug 8, 2012
lol, found the fella w a quick search.![]()
spotted another hint.....
Yup, the way I read it, sounds like ST gonna charge $5-$10 for every eSIM replacement toolol, found the fella w a quick search.
No surprises one. They were recruited to maximize 'return on investment'.Yup, the way I read it, sounds like ST gonna charge $5-$10 for every eSIM replacement tooNo surprise I suppose…
As usual, milk it until its done then move on to the next.Yup, the way I read it, sounds like ST gonna charge $5-$10 for every eSIM replacement tooNo surprise I suppose…
Is it? What is your phone model?I realised 1 problem with esim is that it will stay in your profile even if you delete the esim and it shows as “no sim”.
imagine you got to 10 countries and use different esim but it stays there when you delete the esim.! Then can’t add anymore esim since you can only have 10?
iPhone 14 pro maxIs it? What is your phone model?
The profile shouldn't remain from my experience.iPhone 14 pro max
Can’t say who or where, 1 of my friend been using SingTel esim for years liao. Just not opened up for public use.
Not bragging, just maybe got NDA, not convenient to reveal more but can say he using the esim for years already.not sure is this some kind of brag but definitely some had to be on esim, for testing.
if telco esim doesn't allow easy migration to new phones, it's useless.
Just press on eSIM section and press update contact. It will do nothing and remove that eSIM completely.I realised 1 problem with esim is that it will stay in your profile even if you delete the esim and it shows as “no sim”.
image not found??!![]()
only apple can force our operators to switch to esim if they release slotless sim to sg market.When will all the clowns change to esim? I wished apple release none sim version worldwide for iPhone 15 ultra
yes. Senior plan $5/mth esimhey guys, cheapest esim still simba right?
