Samsung Galaxy S23 series
Jurong640
IMHO.
I have been hoping for a long time already. :ROFLMAO:
Can't wait, then both my lines will have 5G.
Surprisingly my mom's Iphone 14 also dont have 5G with Simba.
Having both lines on Simba, 4G+ and 5G NSA, i can say no much difference. Don't expect speeds up to 500mbps. The highest so far i got on 4G+ was 150mbps and 5G NSA was 227mbps
albel81
IMHO.
S23 should already have Simba 5G. If you can't see it, likely your area don't have coverage. I was nearby Farrer Park MRT recently and saw it shows 5G on mine.
In case you are using power savings mode, remember to allow 5G. By default power savings will disable 5G.
guile
really? will check it out when I'm near Farrer Park. I'm not on Power saving mode though unless battery below 25%.
guile
Ah, so its not that high.
Highest I got on Singtel 5G is 852Mbps at home which is as fast as connecting to my wireless router on Wifi 6 at 160Mhz bandwidth.
keenklee
IMHO.
There is 5G coverage in my area as I've gotten it before.
keenklee
IMHO.
My new record for Zym 5G.
guile
IMHO.
that's good speed. i do a few of these tests and realise it ate up my data pretty quickly. lol.
which area do you stay that you're able to get 5G on your Simba for yr S23?
frizee
Uhmmm, anyone of you having Playstore Device is not certified issue?
Can't seem to find a solution for this though, I'm on the latest July update and I updated it out of the box. :)
keenklee
IMHO.
Eh... apologies I cannot disclose my location.
Anyway it is not S23 Ultra. I using the budget of the budget Samsung A14 5G. Makes no difference as now cannot get Simba 5G after the firmware upgrade.
The Zym 5G that is over 1500 Mbps, also the same Samsung A14 5G.
gapboy
IMHO.
his location is fbi secret dont ask :LOL:
lzr1984
Just to check any promotion offer for Samsung Galaxy S23 Ultra? seen like the samsung website better discount right?
