mosmos
High Honorary Member
Only at B1. I suppose due to x-ray machines there. But vivifi seems ok. Once outside was back to normal.
Even on North-south Mrt line, the loading was also slower than vivifi.
Any complaints about no signal at other locations?
i used at ncid B1 inside room got reception, quite fast. Next time you can walkover to ncid B1 to try out, got basement linkage
Jurong640
East side. Phone is Redmi note 11
never say if it's in the open? Indoor? At home? In Shopping mall? Basement?
Like i said before, each telco has it's weak and blind spot. find one that suits your needs. I personally encounter simba with weak blindspot, but other areas much better than m1
nuscape
Move esim to different phone must come walk in and new QR code cannot be done via calling CS or online, correct?
zzxxzzxx
Jurong640
NDP promo, time for free $5 for all your excess charges when your roam overseas. good when you have upcoming long trips overseas for year end holidays.
endori
My mum's number (m1) is currently under my name. I intend to port both my and my mum's to SIMBA. Anybody knows if I can do so (have 2 numbers under same name under SIMBA)? To clarify, both are post-paid plans.
hwsstx
07.00am - started port-in process from Singtel to SIMBA
11.30am - collected SIMs
11.05pm - Singtel cut me off
01.11am - port-in successful!
Very fast!! 👍👏👏
... within 24 hours!
Yes can be done - both my partner & me under Seniors Plan, under my name, email etc. SIMBA allows 4 numbers under one name.
Your Mum & you porting over to Seniors Plan? Not sure how port-in will be affected if you're not Senior & you're applying Senior for her as your NRIC will show your age.
Although both under your name, both are separate accounts (separated via mobile number) ie when logging into SIMBA's app with her number she will receive SMS OTP.
However no OTP needed when using Website to login.
So, you may want to consider, when Porting over to use the same password etc in the port-in submissions/forms as you will need to submit separate port-in applications ie SIMBA doesn't have a single form/submission for 2 or more numbers.
CPTMiller
i have only obtained download 8.57 Mbps and upload 0.16 Mbps using Simba via speedtest.net
while using M1Maxx, i have obtained 80.6 Mbps and upload 62.3 Mbps
It's very normal to get SIMBA download upload speed less then 10Mbps.
In the past they are the only $10 with 100GB. Now more alternatives
keenklee
IMHO.
A heads up Simba subscribers ( within the last 2 months ) do check SMS working or not.
I encountered 1 case. :ROFLMAO:
