Google Pixel Buds Pro
limmk
Is this PBP worth buying? Now $219AUD
Compared to earlier buds, this is the true wireless (*cough 2018) buds. with ANC (cannot tweak the levels). benchmarking against competitors, may not be your cup of tea. it also depends to your listening. genres are only part of the equation. but in order to use spatial audio, you will need a p6 series and p7 series
limmk
Google is not referring to a specific model (Pro, A-Series, etc.) today.
Have you ever experienced low volume on your buds or humming sound? These situations are not ideal but have the possibility to happen right in the middle of our favorite song or on a call or during the most intense part of a movie.
GOOGLE
Notably, these steps require going into Android’s Developer options. To enable that, go to Settings > About phone and tap “Build number” several times.
The instructions for boosting volume are split between Pixel and all other Android devices. On Google phones, it involves switching off “Disable absolute volume,” which is off by default on Android 13 and 14 devices we checked. Find it under the “Network” sub-menu, but you can just search for it:
  1. Go into your phone settings
  2. Tap System
  3. Tap Developers options
  4. Under “Networking” turn “Disable absolute volume” off
Revolee993
How do these pairs of buds fare so far? I'm currently using Buds 2 Pro but looking to pick this up together with P8P.
Loser
Is google going to be launching the google buds pro 2 anytime soon?
So this upcoming event is just new colors for the buds pro right?
