Jurong640
Just states "Unable to send OTP. Please ensure the number is correct and try again."
Just ported in right? Wait a few days, my friend previously also ported in and for a few days cannot sign in. Try again in a few days, did u happen go collect sim card at Bukit Batok? I suspect there might be some issues with their system.
Velton
yes. I frequent Tuas, simba is very good there as compared to Singtel and Starhub. Previously Simba is average there, but they improved alot and installing many antennas in Tuas area
Yes I'm getting good coverage all over actually.
Not bad!
sohyinwen
Is it normal for SIMBA to have such slow internet? Using two sims.
Singtel has 60mbps
SIMBA is 6mbps….
both are full signal in raffles area. Other areas also the same actually.
CPTMiller
Singtel has 60mbps
SIMBA is 6mbps….
If you are in the shopping complex then may get good speed simba.
