Using E-gate MegaThread
lordfa9
Some say fail few times then pass using the extreme right side Egate
yea generally I will go to the egate on the extreme left or the extreme right of the halls
The ones facing front-wards on the left side of the hall are the oldest and have the highest chance of error
adven7
all finger scanners are down/disabled/not in use for like afew mths or smth liao
Renewal my passport recently and need to re-register for finger print but custom officer reply not sure when finger scanner can be up. Had to use manual lane for the time being.
Do update here if finger scanner can be up. thanks
SantyBalls
There are checkpoint fb groups that always have ppl asking. It's down for mths rdy
bumdssa
is the manual counter finger print thingy the 4 fingers and thumb scanning?
i have not registered for MDAC but went to Penang back in Jun and remember doing the finger print scanning.
any chance that i dont have to go through the manual counter anymore if i registerer for MDAC?
hwsstx
If before entering Penang you didn't submit MDAC, then very likely you can't use E-Gate but can try...
bumdssa
thanks! will find one weekday to go try try. manual counter probably not so long queue also if i need to go to manual counter.
Habrosus
2 forefingers
TLCTLC88
If I register tomorrow via manual counter when entering, can I use e-gate when exiting same day or still have to use manual counter?
SantyBalls
2 train of thought here. the kiasi kialan ones will tell you best to match the entry and exit stamp.
for me, i will tell you per my personal experience the stamps dont matter. u wannt switch it up, auto, manual, its up to you. just tell them egate not working when they ask, and show them the mdac registration email when they ask.
edit: and btw, ytd night alot of ppl egate failed when returning to sg and need go manual. cant remember, but 2 or 3 failed attempts is straight directed to manual.
if 1st time they ask you to proceed to manual, go to the right side egate and try again. if still cannot, u suay and need manual anyway.
the machines on the right are newer.
hwsstx
Some Officers say can Exit via E-Gate but not always successful.
In my case I prefer to have both Entry & Exit stamps, & try to E-Gate the next Entry.
