Milo-Dino
- May 15, 2009
U out casing should already be above the screen protector right.Hi, I just bought the Mi 13u, found that the bottom screen is quite sharp, can feel it when I swipe it up, do you guys have the same feel or is my unit bottom screen got issue?
Update: there's factory applied SP (or TGSP), no wonder.Do you guys peel it off and replace it?
Thanks.
To be honest, I find the factory sp quite good and thick. Only thing is it attracts some dust and leaves some finger prints
