POCO F5 series
i1magic
Miui widget got a default screen lock widget.. Use that one.
Thank you so much! I didn't know that MIUI has this already.
Problem solved.
Now left the notification stays for too long problem, any solution?
Nakedtoes
Problem solved.
Last time I using redmi k30 pro also same issue after latest rom update..
progene
Question.
Anyone manage to connect Poco F5 to healthy365? What are the steps.....
monoblue
Just to share, I have tested my other device that is on miui 13, the google map compass is working fine and found in redit discussion mentioning its a miui 14 issue...
The current workaround that works for me is open google map setting and clear all data. Need to do it every time you open goggle map.
MIUI just release a update Global 14.0.5.0, finally Google map compass is fixed for me.
orpisia
Emeritus Honorary Member
hello all
on shopee it says Your parcel has departed from Hong Kong sorting centre on 12th Aug
until now no update
usually take how long?
frizee
hello all
until now no update
I think overload from 8/8 orders bah, usually delivers in 1 week or so.
human_shieldz
Just got my Poco F5 today!! You guys got the GetApps app?? OMFG that's so fxxking annoying!!! Is it a Poco or MIU thing? My Poco F2 Pro and Redmi Note 9S don't have!
