Brother or HP colour laser printer?
Singrish
Am looking to buy a colour laser printer (just printer no need scan/copy) for home use. Have read online and seems most recommend HP or Brother.
Based on my budget these 2 are the likely contenders:
Brother HL-L3270CDW about $361
HP 150nw Printer $379
Both have auto duplex printing but Brother is a bit faster. However I notice the HP toners are about $20 cheaper than Brother. Obviously this will make a difference in the long run pricewise since there are 4 different toner colours to replace.
Having said that I see Brother colour toners are rated at 1300 pages vs 700 for HP colour toner so technically Brother toner is cheaper 🤣
Are Brother toner cartridges easy to find in any IT shop compared to HP?
Is there anything else that I should know about HP vs Brother which could influence my choice? In terms of product reliability and tech support perhaps?
I am a mac user but I assume no issues with drivers and compatibility?
Have used only canon inkjets prior to this so totally new to laser šŸ˜…
Reavl
Just nice i am also looking at Brother printer, read a lot reddit recommending mono brother laser printer but i am looking for colour.
Currently looking at this model Dcp-l3551cdw.
vaxvms
one more thing to take note for max pages print out
if they say 3000 pages high yield u will only get this figure if black color setting is at dimmest
orangeredbluediamond
Don't buy ink type if you print not often. Inkjet printer dry up & maintenance hassle. Refill ink also messy. Laser best if you print not often. If heavy printing then use ink type.
watzup_ken
Based on the news of HP printers of late, I would prefer to steer clear myself. You can Google and find them before making a decision.
