esim discussion
froztheart
:s8: :s8: :s8: spotted another hint.....
lol, found the fella w a quick search.
elvintay07
Suspended
I realised 1 problem with esim is that it will stay in your profile even if you delete the esim and it shows as “no sim”.
imagine you got to 10 countries and use different esim but it stays there when you delete the esim. 😆! Then can’t add anymore esim since you can only have 10?
Kiwi8
Deluxe Member
Is it? What is your phone model?
kashix
Can’t say who or where, 1 of my friend been using SingTel esim for years liao. Just not opened up for public use.
zobrak
not sure is this some kind of brag but definitely some had to be on esim, for testing.
if telco esim doesn't allow easy migration to new phones, it's useless.
kashix
Not bragging, just maybe got NDA, not convenient to reveal more but can say he using the esim for years already.
Fellowes
Just press on eSIM section and press update contact. It will do nothing and remove that eSIM completely.
elvintay07
Suspended
When will all the clowns change to esim? I wished apple release none sim version worldwide for iPhone 15 ultra
xonix
zekai
I hate ESIM.
Good Points
1. Convenient, can be delivered to you over email anywhere in the world
Bad Points (everything turns to ****)
1. My Circles.Life ESIM qrcode failed to be delivered by their server. (They had an issue with m1 5G server)
2. Trying to set up a new phone, you need to pay to regenerate a QR CODE. (What the hell man, I probably will just number port and switch telco)
3. If your phone fails at night, and you get a **** service like SIMBA. No one to regenerate a new QR Code for the new device outside operating hours. (It used to be easier just putting the SIM into a new phone)
ESIM sucks as the local operators cannot issue it seamlessly and with added cost.
Using it during travels is still not so bad BUT, beware if you do not receive the QR CODE, you may go crazy.
