QCI Values thread
Kiwi8
Deluxe Member
I installed the app, granted Superuser rights for it using Magisk. It got stuck there on "Checking Device Compatibility". :s22:
My phone is Samsung A8 Star.
Mach3.2
CMLink's $20.8 plan QCI is also 9. We can probably assume all Singtel MVNOs are QCI 9.
I think main question right now is the QCI for singtel's regular sim only plans, the more expensive phone bundled plans and the priority/enterprise plans.
ugene
Can concur, just tested CMLink's $10 for 100gb promotional plan
Same QCI 9
ugene
Anyone knows the value of redone? Giga? M1 Maxx?
REDOne is ...., see screenshot, QCI 150 !! :eek:
ugene
SingTel:
  • Zero1 Basic $10 - QCI 9
  • GOMO 5G $25 - QCI 9
  • Zym $18 - QCI 9
  • CMLink $20.9 -QCI 9
  • CMLink $10 for 100gb -QCI 9
StarHub:
  • MyRepublic 5G Standard - QCI 7
  • RedOne - QCI 150
M1:
  • Bespoke (old) 30GB for $20 - QCI 9
  • SurfValue 500MB (bundled with broadband) - QCI 9
Simba/TPG:
kylnxa
Tested using what phone? I think might be a bug since QCI typically maxes out at 9 for normal data connections.
https://en.wikipedia.org/wiki/QoS_Class_Identifier
That's not necessarily true. AIUI the QCI is just a value. The operator can set it to whatever they want as long as their backend supports it.
There are some standardised values which is what is listed in the Wikipedia article you linked. But operators are free to use any values they want. Also quoting that article, emphasis mine:
QCI is a scalar that is used within the access network (namely the eNodeB) as a reference to node specific parameters that control packet forwarding treatment, for example scheduling weight, admission thresholds and link-layer protocol configuration.
Anyway, I got 170 for Giga, as reported by my OnePlus 5T running LineageOS 20.
Hi1307
Interesting that RedOne is prioritised over Giga
amazingone
Singtel SIM Only 4G $20 plan
- Data: QCI 9
- Voice: QCI 5
Singtel free mobile line with 512MB data
- Data: QCI 9
- Voice: QCI 5
Circles $0 Flexi plan
- Data: QCI 9
- Voice: QCI 5
All above tested with a Redmi Note 4 (mido) on MIUI 10 Global v8.12.20 ROM
