OnePlus 11 series
tkte_85
Just that this time round export models dun cost that much lower and official sets provide a 2nd year warrenty too. Also like I mentioned there's the extra risk/trouble involved since now there's region locking from this gen onwards. Alot of buyers just wanna buy and use, not buy and troubleshoot for days and even have to go service center and risk getting rejected too since it's not bought officially from them
chickenmedium
I'm ok with OxygenOS, that time issue is with battery life. How's it on 11?
hope you hooted it, i got mine few weeks back and the battery life is great. although i dont do gaming but i play youtube videos for my son to watch, the battery life isn't too shabby. best thing is the 100W charging, go shower come out dry hair the % almost 100 liao :s13:
Veloso
I did. Hahaha. Couldn't take it anymore, $872.
Haven't started using yet, casing and screen protector also arrived already, will set it up soon when I have the time. Can I just kpo a bit, your set manufacturing month also April 2023?
I normally don't use the box charger one, keep using back the same old one unless really is slow until cannot. Currently plugged into socket one is this 100W 3rd party charger.
KeYoKe
Wah nice la... Hope u like it....
wakokokoyz
AIL4fc-cbFKuDo-PTussKxeFD44BYMMy5hB_iTKfONaiUJZC2X--gLN3Y-NKz354i5XoFAJyudKTXtSd9NdbSDhTIzNJoX0xkPFjm5MxrZt47gWnCW0n23Or=w2400
yum😋
liehuo
Any issues on op11 with Google apps like Google pay not working with set from China running colour os?
Any issues if just use color os out of the box?
KeYoKe
Jus get local set. Prevent all such funny issues from bothering u
tkte_85
Wah. Not very cheap leh. Any tricks to get discounts?
if you find a particular phone model's local price expensive, i'd advise not to get that particular model. Especially if you are asking about using it on China Rom. Based on what you are looking at now, i'd say you are not willing to spend over $820-$850 for a Oneplus 11. You do realise that the $850 you are thinking about comes with no warrenty most probably? Sure, shop says theres shop warrenty, be it 1 month, 3 months, 6 months or 1 year max,, and even if they do honor it, they probably are gonna send it back to china for warrenty repairs, which may take a month or 2 depends on if seller is willing to send a single phone back or is consolidating a batch b4 sending back.
If you are buying the phone to only play around and not to replace as a main daily driver phone, then by all means go ahead. Same applies if you dun mind all the issues and troubles that may come after like region locking and china rom issues. In a way, we dun want you to end up wasting even the $820-$850 since u already consider anything above that expensive.
KeYoKe
87x not very cheap? :s22: dont buy it now la. Wait 9.9
Last promo is about 87x for a sd8g2 phone. How cheap you expect it to be sia?
Export set op11 is also around same price with the risk of region lock. And no warranty. Local set has 2 years warranty for a peace of mind
Veloso
Any ways to turn off Google discovery? The page where you swipe left from main home page to access.
liehuo
Make sense. $800+ for Op11 local is indeed worth.
Just for my knowledge, why cant just use China set with color os without converting to oxygen os?
Is Google pay and other Google services working on color os?
Veloso
I am guessing because OP used to be can easily flash to global rom one, which is more stable than CH rom + Google services IMO. Like why use CH+Google when you can have official global rom right. Lol.
But now entirely different story liao, got region lock, both method also cannot work liao. You flashed liao 2 weeks later lock, you don't flash 2 weeks later also lock.
