- Mar 9, 2004
T60: Connectivity.
MR4: Sound.
MR4: Sound.
Can consider V2. Just a bit more.sadly no hdmi if not canot hoot for my xbox s
V2 also no hdmi only havr arc. i m using an old AOC tv . no ARC.Can consider V2. Just a bit more.
ARC is HDMI that carry audio file. It's the same as HDMI. ARC port will act as regular HDMI if arc function is not turn on.V2 also no hdmi only havr arc. i m using an old AOC tv . no ARC.
only stage 360 have hdmi but at that price might as well go for katana
I think he means he wants a passthrough from xbox to soundbar to tv, with v2 however he needs to connect xbox to tv via hdmi and optical out from tv to v2 since tv has no ARC.ARC is HDMI that carry audio file. It's the same as HDMI. ARC port will act as regular HDMI if arc function is not turn on.
So ARC & eARC are only supported by HDMI?ARC is HDMI that carry audio file. It's the same as HDMI. ARC port will act as regular HDMI if arc function is not turn on.
So ARC & eARC are only supported by HDMI?![]()
Hi all, Need some advise regarding the Edifier MR4 that I had just bought.
The Power button if pressed once is to switch between Music (Green Led) & Monitor (Red LED) mode right?
However I only got Monitor mode (RED) and if I pressed once, the Red LD will blink without any sound.
Secondly, May I know what's the Low & High frequency Trimmer button for?
Chinese version has extra mute function, press once to mute, press twice quickly to change mode.Hi all, Need some advise regarding the Edifier MR4 that I had just bought.
Thank you, i google but still don’t understand… guess I just leave it as 0 first.I dont own the MR4
But low/high frequency trimmer is basically low and high shelf filter
They are used to either amplify or attenuate all the frequencies above (high shelf) or below (low shelf) the frequency cutoff point
Thank you, will give the double press a try tonight.Chinese version has extra mute function, press once to mute, press twice quickly to change mode.
High knob boost or lower treble frequencies, low knob boost or lower bass frequencies
Am i able to connect HDMI from PC gpu port to soundbar HDMI ARC? Will it work to transmit sound only?
Yes, you can connect your HDMI to your soundbar. But it must be to an HDMI input port. The HDMI ARC port is usually an output port meant to display what you plug in to your soundbar to your TV. The only thing that can be sent to the soundbar via the output port is audio from the TV to the Soundbar using the dedicated ARC channel. That channel, as the others have said is only meant for the TV to feed audio to the soundbar like from the TV's Netflix app or from your PS5 connected to the TV instead of the soundbar.Am i able to connect HDMI from PC gpu port to soundbar HDMI ARC? Will it work to transmit sound only?
Easy, Just buy LG C3 42" TV and you can use eARC function from PC to TV to Soundbar! Been using LG C2 for a year with eARC enabled amp and there has been no issues.Thanks all, have to reconsider liao
Too big for the viewing distance im using now. 32" seems to be the bestEasy, Just buy LG C3 42" TV and you can use eARC function from PC to TV to Soundbar! Been using LG C2 for a year with eARC enabled amp and there has been no issues.
