keithlim
- Jan 1, 2000
I'll share what I know; other Bros can chime in too.
1. I don't use Android Auto, so can't comment on this.
2. Google Play can be installed and used properly (unlike Huawei phones). Not sure about OCBC App here, as I use iPhone for all banking matters (yes, like some Bros, I carry both Android and iOS phones).
3. The animation effect that I asked earlier was the home screen page, like when you move from one screen to another. In the global rom, it's called transition effects. There's none in the China rom apparently, or maybe it's not available on foldable phones
4. So far so good for me from Lazada. I've been lucky that the phones had no issues, so no RMA needed. I'll always look at the shop ratings and reviews, and usually they'll also indicate (shop) warranty period. I believe they'll help with RMA if need be, but there's always a risk to buy export sets. However, there's not much choice currently, as the XM3 doesn't have global release (yet).
5. I had a hard time previously with Samsung and Pixel watches. I couldn't get them to work with XM2 at all. Then I decided to switch to the Huawei watch, and there's no issue because it uses the Huawei health app to connect. The Huawei watch works well with XM3 too (of course you'll miss out on Samsung Pay, etc).
6. I use GBoard and it's fine. The Swiftkey issue mentioned was (I reckon) due to the miui optimization (leave it on and it'll be fine).
7. Think the 4 camera setup will depend on individuals. I'm not particular about that so I'm fine with it.
Hope this helps.
Thanks bro, this is very helpful!
