PC - HDR Gaming - Sharing Experience
Yongkit
Yongkit, do you need to redo your HDR Calibration if you change GPU but use same monitor?
i would suggest to redo HDR calibration because sometime different GPU and everything reset on monitor due to driver changes.
for I redo calibration everytime i change cable, I am now using the elecom HDMI 2.1 8k cable:
from my reseach on reddit, some mentioned they have some inconsistency with 4000 series gpu on this monitor, may i know if your unit so far ok?
elmariachi
So far everything works fine and smooth. Hdr looks same as my 3080 Ti. Temps and all are good too. Only Jedi Survivor seems to have weird hotspot spike 6 degrees higher than normal at loading menu then become normal once the game starts. Stupid game at optimising game files at menu creates unnecessary GPU load spikes. But very happy with my 4090 TUF non-OC version. Even with 1.07V, I can hit 3045Mhz easy. Nvidia gimped all new AD102-301 Dies to 1.07v. Early batch with AD102-300 were all 1.1V. Anyway got new nvflash which has been hacked to allow 1.07v Dies to flash to 1.1v. Will try it at some point. Best thing is my unit has ZERO coil whine. Not even a faint coil whine when running 550W+ loads.
xtractor
how it goes when u use that 2.1 8k hdmi cable
what is the advantage of it?
does the picture look nicer etc?
Yongkit
Wow very nice 👍
Yongkit
Played some Dead Space at night on my AW3423DW. Absolutely amazing game that showcases HDR can elevate your gaming experience.
i finally tried it through game pass, play until got the cutter then i very scare to continue, very scary but HDR is very nice true black
Phen8210
that's why its called game pass, it has all the games you should pass :ROFLMAO:
watzup_ken
Not so bad la. There are some decent games on the platform. For example, I started playing Controls on it a couple of years back. However, I am unsure if it is worth the current monthly subscription. In most cases, I will use Game Pass to try some games, and buy them if they are on sale. Buying a discounted full game on Steam is even cheaper than 1 month subscription of Game Pass in most cases.
Phen8210
Wasn't serious about it la obviously lol, game pass actually more worth than buying games.
Yongkit
For those interested you can change your browser color profile to HDR10 using the function below type in the address bar
for edge
edge://flags/
for chrome
chrome://flags/
