emozxs
Spigen Ezfit is clear without borders.
Yeah I know, but after the alignment issues, I'm a little wary of the 15PM option. If I have to go back to Spigen, I'll use the 14PM protectors. I have it on my 15PM now, and it's really full coverage, except the small shimmer around the edges. I guess I can live with it since it's not that visible when there's a case on
ceecookie
If using spigen tough armor, edge to edge SP have issue since the case is thicker and cause the SP to delaminate at the edge when directional pressure is applied. Now waiting for thinner SP to be available for swapping out.
I asked the neighborhood hp shop abt 14pm and 15pm screen protector, he say the exact dimension down to individual mm level is different.
xtwis7
Just curious, the random numbers SK-SD83758385737263 is a design? Any meanining to it?
I think it’s just a random string of numbers. SK would be the brand but beyond that I’m guessing it’s random. It’ll be even more cool if there’s an Easter egg behind it.
Lime89
Hi anyone has a usb A to usb C cable that works in CarPlay?
Tried 2 cables cannot work. Only can charge.
I'm using the Belkin BoostCharge Pro Flex USB-A to USB-C cable.
It's a little on the expensive side but it's USB-IF certified with a 5-year warranty. I've tested it to work with CarPlay + charging at the same time.
I bought it because another cable I have doesn't work at all. This is listed on the Apple Store, so I figured there's a pretty good chance it works. Didn't buy it from Apple though cos they only had the white one 😂
A little worried that the rubberised texture on the connector heads would become sticky over time in our climate, we'll see.
Comes with a nice magnet to keep the cable routed away from the cup holders and gear stick.
MagSafe car mount pictured here is a mophie. They have the charging and non-charging variant and you can use it with or without an extension arm so you have options to position the phone in a way that it doesn't block the CarPlay screen. I bought the non-charging one as my car doesn't have wireless CarPlay.
Hope this helps!
kashix
Now I know how strong the Ugreen magnet strength is, I compared to naked phone MagSafe strength. The case is a lot stronger!
