kashix
Just received my SmartDevil screen protector (borderless + alignment tray).
Hi bro can sic link for this?
HZYiLong
: : PSA : :
DO NOT purchase CASETiFY case for iPhone 15 Pro series! It uses the old design that does not support Action Button! There is a cut-out originally meant for Ring/Silent switch.
HZYiLong
Hi all, if the spigen ezfit got alignment issue, what’s the next good TG to recommend with tray installation?
Bro, Spigen no alignment issue, just that it cause bubbles during installation. Bubbles can be removed depends on your installation skills.
Personally, I find the Spigen Glas.tR EZ Fit to be dust magnet on the edges.
kashix
I hooted 2 sets from Amazon SG, yet to use so thinking if got alignment issues as reported. But thank you.
Knightoftheblackrose
Looking for recommendations on good MagSafe compatible iphone holders for my car, which are secure during driving.
I'm currently using a MagSafe Compatible Case with my Iphone.
Thanks.
leongws
I bought Mazer 3 in 1 MagSafe compatible wireless charging stand. So far tested on iPhone 15 pm, from 63% till 100% took about 2hr 15min (1415 till about 1630). Once connected to the MagSafe charger, iPhone screen shows the animation just like connecting to Apple MagSafe charger.
To me it is acceptable if I’m not in a hurry. Not sure what is the wattage during charging though I suspect it to be 7.5w. Understand Apple MagSafe charger able to charge at 15w.
https://shp.ee/2etm4v9
BlueBull
: : PSA : :
Don't understand what you mean. I'm using Casetify case for my IP15PM and there is a cutout for the action button that allows me to use it to start camera app and take photos easily.
runforyourlife
Moderator
Moderator
He meant it should be a button and not cutout.
cutout is just lazy way out for most manufacturers.
nomad is one of e few leather case that has a button for the action button
Just wanted to share my experience with the NOMAD branded Iphone Case for my IP15 Pro Max.
It is MagSafe compatible and works with Magsafe Chargers.
My phone sticks very well and does not drop off a vertically positioned MagSafe Charger (Belkin).
It has an overall Premium Luxurious feel with a real leather back and all the side buttons are made of real metal.
There's 2 versions, the cheaper normal leather version at $59.90 or $89.90 for premium leather.
I purchased the cheaper $59.90 version and feel that it is not really that expensive.
Other MagSafe compatible branded cases such as Spigen can cost you over $50 bucks, and they are made of cheaper plastic TPU materials, including the side buttons.
This NOMAD case is made of real leather. All the side buttons are also made of metal.
sg-11134207-7rbnd-lm4bmxra88k96a
BlueBull
oh I see. ok, understood. I prefer the cutout as the hole is tapered from outer case portion. Allows even my fat finger to access and press the button easily.
discoburg
Where you purchased it? Website show USD50
