- Jul 5, 2001
Is it slower than P7P?Charging is slow like turtle, haiz...![]()
About the same...Is it slower than P7P?
Depends on what you get. Only the brown one is using 'good' leather. The rest are eco tanned leather (especially the colored ones). Eco tanned leather = fake leather. The color drops off after a while; you can head to reddit to read about it.Anyone using bellroy leather case for p8p? Is it good?
I've replaced my sim card at causeway point. It works now but the 5G signal is not good. Always 1-2 bars. I previously had the old sim card in my S23+ and it was always full signal. Any Singtel customer having the same issue with their P8P?
Singtel here, that happened to me too when I switched to p7p last year. Dun worry about the low bar. Still can use...Ah so that one right is an AOSP thing. Android has a different calculation for 5G SA bars compared to 4G. For 5G SA you need at least -70dBm to see full bars whereas for 4G you only need -100dBm to see full bars.
Basically as long as you see 1 bar of 5G SA your internet will be good. If your 4G is not full bar means problem already
Black is one of the better ones.
In order to use Magic Editor, its forcing to take back up? Is this correct guys?
This is unnecessary headache!
Getting my p8p porcelain 512gb next week from NYC. Got it together with the pixel watch 2.Anyone here using the US p8p version?
Can i ask if US version can work without issues in SG?'
As I have a friend who is coming back SG, thinking of asking him to buy 1 for me..
